Results 1 to 6 of 6
    New ROGer Array
    Jan 2019
    7
    Red face My G752VT optical drive went rogue
    Hello, my Laptop is a Rog G752VT - GC040T. Bought in 2016. Since the 7th of June my optical drive isn't working anymore. It's still visible in file explorer and device manager showing no issue. But if I try to insert a CD, DVD or bluray, it tries loading them but then nothing happens. What can I do to fix it??? Thanks
    David
    ROG Guru: Gold Belt Array Clintlgm PC Specs
    Clintlgm PC Specs
    Laptop (Model)Asus G752VY DH72
    MotherboardAsus Z97 Pro WiFi and /Z97 Pro A
    ProcessorI7 4790K
    Storage #1512 GB M.2 Samsung 960 Pro
    Storage #21 TB Samsun 850 Pro
    CaseCool Master Haf
    OS Win 8.1 Pro and Win 10 Pro
    Clintlgm's Avatar
    Jul 2012
    111
    4,177
    Replace it.
    G752VY-DH72 Win 10 Pro
    980m GTX 4 GB
    32GB DDR 4 Standard RAM
    Z97 PRO WiFi I7 4790K
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    New ROGer Array
    Jan 2019
    7
    OK. Is it easy to replace an optical drive in a laptop? Is there a tutorial for ROG laptops?
    ROG Guru: Black Belt Array toronto699 PC Specs
    toronto699 PC Specs
    Laptop (Model)G752-VY-DH78K , G751-JYDH72X
    MotherboardRog Tytan G30AB
    Processori7-4770K
    Memory (part number)32GB
    Graphics Card #1Asus Gold20th GTX980Ti
    Sound CardDell X-Fi Audigy SoundBlaster
    Monitor3 Acer K272HL
    Storage #1118 GB/OS
    Storage #22.72 TB
    CPU CoolerIntegrated Liquid-Cooled CPU
    CaseG30AB
    Power SupplyAsus 700 Watt
    Keyboard Razer BlackWidow Ultimate
    Mouse Razer Diamond Back
    Headset Sony Studio Professional , Razer Seiren Mic
    Mouse Pad Razer FireFly
    Headset/Speakers Logittech 5.1 Z-5500
    OS W 10
    Network RouterSagemon Fast 5250 Hub 2000
    Aug 2014
    96
    2,509
    Clintlgm PC Specs
    ProcessorI7 4790K
    CaseCool Master Haf
    Clintlgm's Avatar
    Jul 2012
    111
    4,177
    Quote Originally Posted by PinguThePenguin View Post
    Utube probably several Videos
    980m GTX 4 GB
    Windows 10 Pro
    Z97 -A
    Windows 10 Pro
    New ROGer Array
    Jan 2019
    7
    Thanks a lot!
    I also found this one :
    https://www.youtube.com/watch?v=8i469-c62rg
    And in the following video, the guy takes off the Optical drive :
    https://www.youtube.com/watch?v=fxjw1rBHWR8
    Also this video could help maybe :
    https://www.youtube.com/watch?v=et3KXhoNTr0
    It seems easy
    But I was wondering what kind of Optical drive should I purchase? Can I buy any slim internal burner ? Or is there a special drive format I should care about?
    Thanks
    DS
Tags for this Thread
