Results 1 to 3 of 3
    ROG Enthusiast Array BLOODCHILLER PC Specs
    Motherboardmaximus v gene
    Processori73770k
    Memory (part number)CORSAIR 32GB
    Graphics Card #1ROG-STRIX-GTX1060-A6G-GAMING
    MonitorXG27VQ
    Storage #1ssd evo samsung
    CPU Coolercorsair 110i
    Caselian li armorsuit
    Power Supplycorsair 850
    Keyboard razer
    Mouse razer
    Headset HYPERX
    Mouse Pad razer
    BLOODCHILLER's Avatar
    Jun 2013
    42
    Need help with Fan Headers !!!
    Hi all curently i am in the final stage of collecting parts for my NEW build and i have come to realise i need to power up about 11 fans incuding ofc the water coolers fans i would like your help once again .
    case : Lian Li Dynamic 011 XL ROG
    motherboard : asus ROG GENE XI Z390
    CPU COOLER : KRAKEN x 72
    fans : for intake - 6 on the 360 kraken 2 on the botom of case these fans will be Noctua NF-F12 PWM Chromax Black 120mm more specifications are
    Max. input power 0,6 W
    Max. input current 0,05 A
    Operating voltage 12 V
    For exhaust i am thinking of using the 3 fans left over from the kraken x72 nzxt fans but not sure yet.
    position of fans is 1 on the back and the last 2 on the top !!!
    Problem the gene motherboard has 5 fan slots manufature says the motherboard can power 7 fans how do i work out how to put fans and how many fans on what spliters ect ect unfortunatly i canot get a fan control panel from asus in my country and there is a posibility the node slot will not regognize it because in specifications list there is no mention of the node slot .
    So i need some help on how to figure out what to do please ?
    On my old build it was kind of strait forward i put the motherboard in pluged the 2 cables from the case in motherboard and fans started up the same with the cpu cooler pluged in slot and it started but with the new case things are diferent i may need to by somethink to control fans since only 2 slots on gene motherboard are linked to software the other 3 run on auto max fan speed and the last thing i wana do is damage my motherboard been collecting parts for a long time to build a new pc
    New ROGer Array Braegnok PC Specs
    Braegnok PC Specs
    MotherboardAsus ROG Maximus XII Extreme
    ProcessorIntel Core i9-10900K
    Memory (part number)F4-3600C14D-32GTRS
    Graphics Card #1Nvidia RTX 3090 FE
    MonitorAsus ROG Swift PG35VQ
    Storage #1Samsung 970 Pro 1TB
    CPU CoolerOptimus SV2
    CaseTT A700 TG
    Power SupplyCorsair AX1600i
    Keyboard Das Keyboard 4 Ultimate
    Mouse G502 Lightspeed
    Headset SteelSeries Arctis Pro
    OS Windows 10 Pro 64-Bit
    Accessory #1 Watercool MO-RA3 420 Pro
    Accessory #2 D5-Dualtop Module
    Braegnok's Avatar
    Nov 2019
    140
    I use all my motherboard fan headers with Y spliter on front fans controlled with BIOS Qfan, and use the Phanteks Universal Fan Controller for all the rest.
    Phanteks : http://www.phanteks.com/PH-PWHUB_02.html
    Processori73770k
    MonitorXG27VQ
    Keyboard razer
    Mouse razer
    Headset HYPERX
    Mouse Pad razer
    Jun 2013
    42
    Quote Originally Posted by Braegnok View Post
    Thank you m8 i will do my looking around and get one of these fan conectors tbh i am between these one and the small litle noctua one .
    Kind regards Terry
