Results 1 to 7 of 7
    New ROGer Array
    Jun 2020
    3
    ROG STRIX Z490-H motherboard logo led
    According to https://www.asus.com/us/Motherboards...Z490-H-GAMING/ the ROG logo by the IO shield is customizable, however when I select a new option in armoury crate nothing happens. It seems to just be stuck on the breathing option in red. Is there some setting I might be missing somewhere?
    ROG Guru: White Belt Array oG kill3r PC Specs
    oG kill3r PC Specs
    MotherboardZ390-H
    Processori9 9900k
    Memory (part number)CORSAIR DOMINATOR 3600 32GB
    Graphics Card #1PNY RTX 3080 XLR8
    Sound CardSOUND BLASTER G6
    MonitorASUS XG43VQ
    Storage #1SAMSUNG 970 PRO M2 512GB
    Storage #2SAMSUNG 970 PRO M2 512GB
    CPU CoolerNZXT M22
    CaseNZXT 710i
    Power SupplyCORSAIR HX1000
    Keyboard CORSAIR K65
    Mouse CORSAIR DARK CORE RGB PRO SE
    Headset BEYERDYNAMIC 990 PRO
    OS WINDOWS 10
    oG kill3r's Avatar
    Feb 2012
    108
    You have to set it in bios . Try this " Bios > Advanced Mode > Advanced > Onboard Devices Configuration > SupremeFX LED Lighting > Still Mode"
    New ROGer Array
    Jun 2020
    3
    Quote Originally Posted by oG kill3r View Post
    I don't see that option...
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 64 bit 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    319
    582
    This setting is specific to your motherboard, not hers.
    Quote Originally Posted by dschu012 View Post
    This is normal, as I explained to him, this is specific to his motherboard which is not AURA Sync.
    Regarding your motherboard, it is an AURA Sync compatible motherboard and you have AURA Sync RGB headers on your motherboard to allow you to control your AURA Sync RGB fan/devices/etc., but beware that the onboard lighting of your motherboard does not have RGB lighting, only red lighting (as has always been the case for the ROG Strix xxxx-H motherboard range) :
    New ROGer Array
    Jun 2020
    3
    Quote Originally Posted by MoKiChU View Post
    thanks. up until a few days ago the https://www.asus.com/us/Motherboards...Z490-H-GAMING/ showed it being customizable, which caused the confusion. looks like since then that overview has been updated.
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    319
    582
    I think that it's the word "Customizatiion" (circled in red on the screenshot below) which caused your confusion :
    I doubt that the overwiew page has changed because as I told you, lighting/style has always been red for the ROG Strix xxxx-H motherboard range.
  7. #7
    ROG Junior Member Array
    Aug 2016
    1
    Is it possible to make the logo static on?
    The logo being just red is fine, but pulsing is annoying. Can it be made to just stay on solid static?
    Kind regards
    Tim
