Results 1 to 4 of 4
    New ROGer Array
    Jun 2020
    2
    Exclamation Asus ROG x570 Crosshair VIII Hero (Wifi) RAM Speed Issue
    Hello,
    I have been having issues with my RAM speed. The current speed is running at 3466 MHz, where as my hardware speed is 3600MHz. When I set the RAM speed to anything over 3466 MHZ I cannot get post and the Motherboard displays Q Code 22. I have been testing back and forth and the maximmum number I can set without any issues is 3466MHz. I am using G.Skill TridentZ RGB Series 16GB DDR4 3600MHz. I just updated my BIOS version to V1302 but there is no change. During my tests the FCLK is set to auto which is 50% of the RAM speed. I also tested 3600MHz with 1800MHz FCLK or lower and still cannot get post and I get Q code 22.
    Here the current outcome for cmd "wmic MEMORYCHIP get BankLabel, DeviceLocator, MemoryType, TypeDetail, Capacity, Speed"
    BankLabel Capacity DeviceLocator MemoryType Speed TypeDetail
    BANK 1 8589934592 DIMM_A2 0 3466 16512
    BANK 3 8589934592 DIMM_B2 0 3466 16512
    Also the rest of my hardware info;
    - Asus ROG x570 Crosshair VIII Hero (Wifi) ATX Motherboard BIOS V1302
    - AMD Ryzen 9 3900X Processor
    - G.Skill TridentZ RGB Series 16GB (2 x 8GB) 288-Pin DDR4 3600MHz (PC4 28800) Desktop Memory Model F4-3600C16D-16GTZR
    - Sabrent 1TB Rocket NVMe 4.0 Gen4 PCIe M.2 Internal SSD Extreme Performance Solid State Drive with Heatsink
    - EVGA GeForce GTX 1070 FTW GAMING ACX 3.0, 8GB GDDR5, RGB LED, 10CM FAN, 10 Power Phases, Double BIOS, DX12 OSD Support (PXOC) Graphics Card 08G-P4-6276-KR
    Last edited by siemenscs; 06-18-2020 at 03:39 PM. Reason: At first it displayed random characters.
    New ROGer Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    726
    Make sure you are using from the CPU ram slots 2 & 4
    in the bios use DOCP like this
    In regard flck you reading it wrong, Flck 1800mghz = bus speed of 1800mghz (= DDR speed @ 3600) ie. 1:1 ratio
    Hope you find this of help, I'm off to bed.
    New ROGer Array
    Jun 2020
    2
    Quote Originally Posted by RedSector73 View Post
    Thank you for your help. I am using DIMM_B2* and DIMM_A2* slots and i changed the settings on bios as you suggested it. Everything seems to be working properly now. I highly appreciate the help.
    BANK 1 8589934592 DIMM_A2 0 3600 16512
    BANK 3 8589934592 DIMM_B2 0 3600 16512
    Apr 2018
    40
    726
    No problem, enjoy your new system.
Tags for this Thread
