Results 1 to 8 of 8
    New ROGer Array
    May 2020
    23
    Realtek Audio Drivers and SupremeFX
    ASUS ROG STRIX Z-390-E motherboard with Soundblaster AE-9 soundcard.
    The SoundBlaster AE-9 is used over the Realtek. I would disable the onboard sound in the BIOS/UEFI but I want to keep it active so I can install Linux on a second drive. Creative Labs has poor Linux support at best so I will be forced to use the Realtek onboard sound.
    Questions...
    What does SupremeFX software do? Do I need it? It is bundled with the ASUS sound drivers, right?
    Can I install the Realtek drivers (most updated versions) from the Realtek website rather than the ASUS versions and do without the SupremeFX software?
    Thanks!
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1System : SSD Samsung 960 EVO 256GB
    Storage #2Games : SSD Corsair MP510 240GB | Data : SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 20H2/VB/19042.x
    MoKiChU's Avatar
    Aug 2013
    217
    436
    SupremeFX = Realtek Audio for ROG products, so SupremeFX software = Realtek HD Audio Manager (HDA drivers) = Realtek Audio Control (UAD drivers).
    You need Realtek Audio Drivers (UAD - ASUS ROG/PRIME/TUF MB) from my UAD drivers thread. Follow scrupulously your INSTALL process with cleanup step, for the next drivers packages that I would release, you will can directly follow the UPDATE process.
    Note (in order to choose correctly the install/update process to use) : You have a ASUS ROG SS3 motherboard.
    Also, If you are looking to perform a custom install (like minimal, which is such as Microsoft built-in drivers without any SupremeFX/Realtek Audio software), please refer to this :
    Quote Originally Posted by MoKiChU View Post
    - Minimal (such as Microsoft built-in drivers) : Follow scrupulously your CLEANUP process > Right click on "AUDIO_Realtek_UAD_ASUS_ROG-PRIME-TUF_MB_v6.0.xxxx.x\Realtek\Codec_xxxx.x\HDXASUS.in f" > Install > Wait for the message "The operation completed successfully" or for restart request.
    - Realtek Only (like ASUS ROG/PRIME/TUF RTK motherboards but the equalizer in Realtek Audio Control will not work) : Delete the ThirdParty folder from AUDIO_Realtek_UAD_ASUS_ROG-PRIME-TUF_MB_v6.0.xxxx.x folder then follow scrupulously your INSTALL process with cleanup step.
    - Full : Follow scrupulously your INSTALL process with cleanup step.
    New ROGer Array
    May 2020
    23
    Also, If you are looking to perform a custom install (like minimal, which is such as Microsoft built-in drivers without any SupremeFX/Realtek Audio software), please refer to this post : https://rog.asus.com/forum/showthrea...e15#post807070
    Thank you for the reply:
    A few follow-up questions, comments and clarifications:
    So SupremeFX is just the Realtek Audio platform rebranded and modified for ROG Motherboards, right?
    The next Realtek Drivers UAD release by you can be updated through the normal vendor update process as opposed to the lengthy tutorial, correct? When do you expect to release the new drivers?
    I don't use the ROG onboard Realtek Audio but a Creative Labs AE-9 soundcard instead. I keep the onboard sound enabled to eventually use in Linux. It is my understanding that Realtek sound is better supported in Linux than Soundblaster. In this context, do your UAD drivers support Linux? Should I opt for the minimal driver install rather than include SupremeFX if I don't use the Realtek, but just want to keep it active?
    Thanks!
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    217
    436
    Quote Originally Posted by bamajon1974 View Post
    Right.
    It is technically possible but the install methods are different, so :
    - If you want to switch to the drivers offered on the support page of your motherboard, you need to uninstall the drivers that I offer by simply following your CLEANUP process and then install the drivers offered on the support page for your motherboard.
    - If you want to switch to the drivers that I offer, you must uninstall the drivers offered on the support page of your motherboard by simply following your CLEANUP process and then install the drivers that I offer by following your INSTALL process. For the next drivers packages that I would release (when they are available), you will can directly follow the UPDATE process
    No, only Windows 10 64 bit 1709/RS3/16299.x or more recent.
    Right.
    New ROGer Array
    May 2020
    23
    Right.
    Right.
    Ahhh so since your drivers just support Windows and the only reason I am keep the Realtek integrated sound enabled is for Linux, then I should opt for the Realtek drivers and obtain and install these drivers from their website, right?
    There is no issue with installing the most uptodate Realtek drivers supplied by the manufacturer, right? I have a ROG STRIX Z390E gaming MoBo.
    Thanks!
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    217
    436
    If you keep enabled your audio chipset on the BIOS of your motherboard, it will be active on Windows and Linux, so you need drivers for both :
    If you talking about the Realtek audio drivers for Windows : the drivers from the Realtek support page are obsolete. What's the point of installing obsolete drivers for something you're not using ? If you do not want to install the drivers that I offer or the drivers from the support page of your motherboard, simply install nothing at all and leave the Microsoft built-in drivers.
    If you talking about the Realtek audio drivers for Linux : Linux is not my field, I cannot advise you.
    Thanks!
    If you talk about use the drivers from the support page of your motherboard on Linux, no they won't work.
    If you talk about use the drivers from the support page of your motherboard on Windows, yes, probably, I can't guarantee the operation of something that I have not packaged.
  7. #7
    New ROGer Array
    May 2020
    23
    OK. A couple of more questions....
    In context of the onboard sound, is ROG STRIX Z-390E Gaming MoBo the S3 or S3+DTS Sound Unbound?
    If I am not mistaken, the onboard sound for the ROG STRIX Z-390E is the Realtek ALC 1220, right?
    If I chose to install just the standard Realtek drivers, can I use the ones from this page?
    https://codecpack.co/download/realte...o-drivers.html
    Thanks!
  8. #8
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    217
    436
    I already answered you ...
    S1220A more exactly like indicated in your motherboard specs.
    If I chose to install just the standard Realtek drivers ...
    I already told you the choices available to you for your motherboard ... the conversation is going in circles and I'm going to stop this discussion here.
