Results 1 to 8 of 8
    New ROGer Array
    Jun 2020
    30
    5
    ROG Zephyrus G 15 - wifi card very slow - seeking help with replacement
    Currently, we are not able to get decent and consistent speeds on wifi. I have tried many things and just simply would like to replace the card with a better one.
    The existing wifi card (AW-CB304NF). However, while I have built my own PC before, I am not very familiar with laptop internal components.
    Can someone help me to understand what kind of card this is or TYPE or FORMAT or SIZE so I can research the proper replacement size?
    Also, if anyone has a recommended replacement wifi card, that will help too.
    Thank you
    New ROGer Array
    Jun 2020
    30
    5
    Here is the existing wifi card.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,819
    Compatibility is pretty good so you should be able to install whatever you want. I've had good luck with Intel WiFi adapters in the past.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Jun 2020
    30
    5
    Is this a good replacement? Will it work (it looks like it has the same connectors but the pins are slightly different for the mPCI slot.
    https://www.amazon.com/Wireless-PCs-...MYNMHXHBZEH25S
    Any recommendations on an even better replacement?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,819
    The last time I bought one was years ago so you wouldn't want the specific one I got. But in general Intel wireless has a good reputation. As for compatibility, as long as the notches (keys) are the same then most m.2 devices are interchangeable. The keys are supposed to keep you from installing something incompatible. Sometimes length or thickness can be incompatible but those appear the same for the one you linked.
    New ROGer Array
    Jun 2020
    30
    5
    Thank you for taking the time to respond. I will report back on my install experience.
  7. #7
    New ROGer Array
    Jun 2020
    30
    5
    Thank you XeroMist for your help.
    I purchased the WiFi 6 AX200 WiFi Adapter. For the install, I did the following:
    1. Downloaded the BT and WiFi drives to my hard drive but did NOT install them
    2. I powered down the laptop and removed the old card and installed the new card.
    3. I started up the laptop, I saw the Network adapter in the Device Manager but it was not installed yet
    4. I then just ran the downloaded executables from step 2
    4a. First, I ran the WiFi executable. I then saw Device Manager update to show the WiFi card
    4b. Second, I ran the Blue Tooth executable, I then saw Device Manager update to show the BT card.
    After this, I did NOT see the internet connection happen. Perhaps I just needed to wait a bit more, but I rebooted, and then I saw the Internet wireless connection happen.
    BT works too.
    My speedtest BEFORE: 10 Mbps
    My speedtest AFTER: 60 Mbps
  8. #8
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,819
    Great! Thanks for reporting your results.
