Results 1 to 2 of 2
    New ROGer Array
    Jun 2020
    1
    Zephyrus duo 15 XS, turbo always on
    Hello all ! I'm an happy new owner of the new Zephyrus duo 15 (XS model). I'm coming from macbook pro.
    I have some troubles with cpu Turbo.
    Whatever the power mode I choose (Windows balanced, ecnonmy, Asus silent / performance), the cpu is running at 4.5Ghz, so my cpu temp is a bit too high.
    The utilisation is around 2%. Not so much. So the laptop is hot under, very hot (the heat is conducted everywhere in laptop)
    First I disabled Asus MultiAntenna service, because it was consumming 1 core at 100%, I supposed it was the reason. If I block the turbo with throttle stop, I see the freqences go to 1200Mhz...
    But as soon as I releease the throttlestop it's going back to 4.5Ghz.
    Another point, it seems, but I'm not sure that I success to undervolt my 10980HK, I was thinking it wasn't possible. Did I miss something ?
    If anybody could help me
    Moderator Array
    Feb 2019
    12
    344
    Hello baalfr76,
    Please kindly PM me your SN and provide the screenshot of situation.
    Thank you so much.
Tags for this Thread
