03-23-2012 05:02 AM - last edited on 03-06-2024 10:25 PM by ROGBot
03-23-2012 05:15 AM
03-23-2012 06:26 AM
HiVizMan wrote:
If you are clocking the heck out of your CPU using water or Air cooling you will need it. If you are cooling your CPU using LN2 when benching the CPU at max clocks you will not need any cooling to the VRM area. Most folks are not even aware their system is throttling because of the heat issued from the VRM at some of the more extreme settings.
03-23-2012 06:31 AM
Stu @ MSD wrote:
Thanks, how can we tell when they are getting too hot?
My case internals are hovering around ambient now, certainly never hotter than 27C, so its pretty cool in there with pretty good airflow.
03-23-2012 05:39 AM
03-23-2012 06:30 AM
03-23-2012 06:56 AM
03-23-2012 07:44 AM
03-23-2012 05:32 PM
01-07-2013 12:05 PM
