Results 1 to 4 of 4
    New ROGer Array
    Dec 2018
    2
    Angry Sonic Studio 3 UAD Need Help
    I recently updated from HDA to UAD and installed sonic studio 3 and realtek control panel from microsoft store.
    But i need some help some things aren't working properly
    Application manager under advanced mode there are some probelms like chrome doesnt show and programs that do show like rust r6 csgo and discord
    sonic studio effects and device routing don't work on then i have tried basic mode that works but i need to add bass / use different effect on some programs at the same time and the old HDA didnt work for me either
    Here are the versions of sonic studio 3 and realtek control panel
    Sonic studio 3 v3.16.10.0
    Realtek control panel v1.12.219.0
    And i used MoKiChU UAD driver v6.0.8960.1 and did all the clean up steps as directed on the forum post
    Here is a screenshot with chrome music playing
    https://i.imgur.com/UtzA7hY.png
    ROG Guru: Green Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1SSD NVMe Samsung 970 EVO Plus 500GB
    Storage #2SSD NVMe Samsung 960 EVO 250GB | SSD NVMe Corsair Force MP510 240GB | SSHD AHCI Seagate FireCuda 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Headset/Speakers Logitech Z333
    OS Windows 11 64 bit 21H2/CO/22000.x
    MoKiChU's Avatar
    Aug 2013
    329
    580
    Which motherboard/notebook do you have ?
    Anyway, you complain about Device Rooting malfunction, but on your screenshot the Device Rooting is disabled ...
    Also note that you can also use Windows Device Rooting (Start > Settings > System > Sound > Advanced sound settings)
    Note : I do not support on something that does not depend on me and which I can do nothing about, if you have any issue with the SS3 app itself, open a ticket to your ASUS Support which will bring your issue to A-Volute (SS3 creator).
    New ROGer Array
    Dec 2018
    2
    Smile Where is there support
    Quote Originally Posted by MoKiChU View Post
    Where can i contact them because i can't use chrome with sonic effects because it won't show chrome xD Edit my motherboard is ROG STRIX-Z270E GAMING
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    329
    580
    Quote Originally Posted by GhostMPG View Post
    Here : https://www.asus.com/support/Product...s/questionform
Tags for this Thread
