Results 1 to 4 of 4
Thread: Maximus XII Extreme
06-25-2020 07:29 PM #1
- Join Date
- Jun 2020
- Reputation
- 10
- Posts
- 1
Maximus XII Extreme
Hi Asus,
Happy I have finally received my Motherboard after a slight delay and its working fantastic. I have got one little issue, which I am confused about. I have 4 fans connected in my unit, with two more being looked after by the Corsair Hydro system. I have three on the front panel, cooling the radiator and one on the back of the chassis. No problem with the one on the back of the case and its being picked up by the motherboard perfectly. I have connected the other three onto the RADIA,B,C headers on the top of the board. However, looking at what I can see, which is only two. I have no vision on the AI Suite software and BIOS. Is this by design or have I forgot to enable something? The fan is spinning fine but I cannot see it! Is this a known issue or typical user error
Regards,
Stu
07-26-2020 05:12 AM #2
- Join Date
- Feb 2014
- Reputation
- 10
- Posts
- 4
I just used commander pro from corsair... and hooked all the fans and leds they lightning node > commander pro*
09-27-2020 07:02 AM #3
- Join Date
- Aug 2013
- Reputation
- 10
- Posts
- 1
Dear, i cannot answer to your question because i'm just interested to buy this motherboard, and i have a question to you: through the Thunderboard minidisplayport is present the video and audio signal from the graphic cpu processor ? I'm interested of not to place the graphic card to optimize the cooling, and have the audio and video signal through the minidisplay port.
Thank you in advance for your answer
Regards
Andrea Serra
09-27-2020 11:42 PM #4
Jesseinsf PC Specs Laptop (Model) N/A Motherboard ASUS ROG Maximus XI Extreme (Z390) Processor Intel Core i9 9900K Memory (part number) Corsair CMW128GX4M4E3200C16 - 128GB (4x32) Graphics Card #1 NVIDIA - GeForce RTX 2080 Ti FE Sound Card Creative Labs Sound Blaster AE-9 Monitor Samsung 32" UH750 QLED UHD Monitor Storage #1 Samsung 980 Pro M.2 PCIe SSD 1TB Storage #2 Samsung 970 Pro M.2 PCIe SSD 1TB CPU Cooler Lian Li Galahad 360 (3x Uni fan SL120) Case Lian Li PC-011 Dynamic XL (ROG Certified) Power Supply Cooler Master V1200 Platinum Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps Mouse Razer Basilisk Ultimate with Charging Dock Headset Bowers and Wilkins P9 Signature Mouse Pad Razer Vespula V2 Mousepad Headset/Speakers Creative GigaWorks T40 Series II OS Windows 10 Pro for Workstations Network Router ROG Rapture GT-AC5300 Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2 Accessory #2 2x Logitech BRIO ULTRA HD PRO WEBCAM Accessory #3 7 Uni Fan SL120 fans for PC case
- Join Date
- Mar 2019
- Reputation
- 23
- Posts
- 247
That is correct, this is by design. Rad 1 fans and Rad 2 fans are seen as two fans. It doesn't matter what software you use. I have 3 fans connected to the Rad 1 headers and 3 fans connected to the Rad 2 headers. The fan speeds I see on the Rad 1 heeders are the average for all three. Same goes for my Rad 2 fans. Also it's the same for CPU fan 1 and 2. Take advantage of the chassis headers like I did. It gave me more control of my fans. Hope this helps.
