Results 1 to 4 of 4
    New ROGer Array
    Jun 2020
    19
    Question Does anyone make their own laptop heat sinks?
    Just wondering if anyone here does welding/heatpipe assembly. I really want to beef up my GL531GT's cooling with the same one thats in the GL531GW. (I Believe the L is just for Backlit keyboard). But since the assembly from the GW and GT are incompatible with one another (Why asus did you move the cpu and gpu in the GT), I will probably have to see about sending someone parts/design and get it all welded together. At the very least I want to get the Extra heat fins (Which i assume are aluminum).
    Basically I want the GW thermal Assembly in the GT (Top one -> Bottom One)
    ---G531GW--- I want all this copper
    ---G531GT--- I have this laptop
    Sooo, Any thoughts?
    Note: My Goal is to have Peak temps of 60 while heavy gaming, and no more then 75 under Artificial Stress
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    318
    7,813
    I don't know... You're talking not just soldering but flat pipes and custom bends. There might not be anyone who does bespoke work like that. It would likely be cheaper to sell your GT and buy a GW if that's what you want. Does the GW even hit those temps?
    It would be interesting to know which was designed first. The GW has a more isolated design with only a single small pipe bridging the chips where the GT has larger pipes spanning everything so that both fans can work together.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Jun 2020
    19
    I found a user on aliexpress who does custom prototype heatpipe builds (guess he probably works in a factory that does it, and might just do it in spare time for the extra cash) its not super expensive to just get the heatpipes bent, but sending the exact dimensions and bends of the pipes isn't that easy without the GW model.
    The Gw has more then twice the tdp as the GT, so more heat to dissipate. I mostly just want cooler cpu and gpu. I might pay for the service down the road. Dont think it will be more then 100$ Cad. (I will have to solder/weld them together but the bends will all be made)
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    318
    7,813
    Well, if you decide to do it please post it because it sounds like an interesting project.
