Results 1 to 5 of 5
    ROG Enthusiast Array
    Aug 2012
    32
    Realtek onboard sound goes to sleep?
    I have an Asus Rampage VI Extreme Omega motherboard and I recently installed the newest Realtek Sound drivers, the Realtek Console and Sonic 3 courtesy of MoKiChU. Everything works a heck lot better than when the old drivers were being used. I love the new controls and software and I want to thank him for his hard work. However, I have one question. It seems that after a period of 5 minutes or so of sound inactivity, like surfing the web, the onboard sound goes to sleep. If I don't prod it awake by clicking on the sound icon and hitting the volume bar to refresh, it tends to stay asleep even when I launch a game. I also have EVERY Sleep and Hibernate setting I can find turned off in Windows, so NOTHING should go to sleep on my system. Am I missing something or is this normal?
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1System : SSD Samsung 960 EVO 256GB
    Storage #2Games : SSD Corsair MP510 240GB | Data : SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 20H2/VB/19042.x
    MoKiChU's Avatar
    Aug 2013
    229
    474
    Try by disabling PCI Express Link State Power Management in your power plan to avoid L0s/L1 state of PCI Express power management mechanism :
    - Windows Control Panel > Power Options > Change plan settings of your current power plan > Change advanced power settings > PCI Express > Link State Power Management : Disabled.
    Aug 2012
    32
    The ONE setting I hadn't changed. Figures. I didn't think it applied to on board sound. Oh well. The only selection to set it to is "Off" on my system, which I selected. So next time I'm surfing for awhile, I'll check to see if it sleeps again. So far so good. If it does it again, I'll let you know. Thanks.
    Perhaps you can answer another question. I purchased a USB HyperX Quadcast microphone. Ever since plugging it in to a USB port and having Windows install the driver, I've been getting an Event 219, Kernel-PnP cannot load the Driver/WudfRd error every time I boot the system as long as it's plugged in. Everything reports as working properly in the Device Manager, no yellow triangles, and the mic works just fine. Any ideas?
    MoKiChU PC Specs
    CaseBitFenix Enso
    Mouse Logitech G502
    MoKiChU's Avatar
    Aug 2013
    229
    474
    Quote Originally Posted by sehlat View Post
    Well, keep us informed
    The generic PnP drivers seem have trouble with your USB mic (which does not impact its functioning however), you have to open a ticket at HyperX support : https://www.hyperxgaming.com/uniteds...ducts/hx-micqc
    Aug 2012
    32
    OK, changing that one setting did keep the sound from going to sleep. Thank you sir.
