Results 1 to 5 of 5
    New ROGer Array
    Jun 2020
    1
    G531GT Short cut keys,rog key,microphone key, fan keys not working properly, slowboot
    Shortcut keys (such as fn+up-keyboard light increase), not working properly. Sometimes they work just fine but many times when I boot up it does not work properly at the beginning though it starts to work after I turn on the armory crate or sometimes on its own. My laptop is G531GT. The boot-up speed has decreased as well. Initially, it used to boot up in less than 10 seconds. Initially, I was having some problems with USB and Bluetooth in regards to which I was told to reinstall my windows by some dumb Microsoft tech assistant but in the end, I solved it through registry settings. I have installed all of the Asus drivers such as gaming center and myasus.
    Moderator Array
    Feb 2019
    13
    539
    Hi theforgottendestiny,
    I have send PM to you, please kindly check.
    New ROGer Array
    Apr 2020
    4
    Facing same issue kindly share the registry changes
    Quote Originally Posted by theforgottendestiny View Post
    hey I am also facing same issues please share the registry edits
    New ROGer Array
    Aug 2020
    11
    18
    A few months ago I also encountered such problem, but now the problem was solved through updates. If does not work, you can enter Armoury Crate and Game Visual, select "Default".
    New ROGer Array
    Dec 2019
    2
    I am having the same issue since last few day, did you get your problem resolved, if yes, how? Please tell!
    Also, I am having some popping/crackling sound on random intervals like whenever I restart my system , the sound comes, if you have have also faced this, please let me know and the possible fix if you have any!
    Thanks in advance!
