Rampage VI Extreme Encore and 8 pin
tistou77
Hello
By mounting the R6EE, I had recovered an 8pin from the R6E and added another 8 pin
And I forgot to plug the 8pin (coming from the R6E) on the PSU :eek: :eek:
I plug it in, and after the double boot, I have the message "Check CPU" on the OLED... I had a bit of a strain... 😞
I turn off the PC, unplug this 8 pin, plug in the 6pin instead and it's good
I checked that the 8pin of the R6E was "wired" the same as the R6EE (to be sure) and of course it's the same
What could this be due to ?
Thanks 😉
PS: I did not try to reconnect it and I will try with 8 original pins (the one I have is "sleeved")
Sorry for my english 😄
Case: Lian Li A77F
MB: Rampage VI Extreme Encore
CPU: i9 10980XE
RAM: G.Skill Trident Z RGB Royal 4x8Gb @4000 C16
GPU: EVGA RTX 2080ti XC Ultra
PSU: Seasonic Prime Ultra Titanium 1000W
OS: Intel Optane 905P PCIe
DATA: Samsung 980 Pro
SOUND: Asus Xonar Phoebus
tistou77
I tested with the original cable and it's good
Not retested with the other cable
Case: Lian Li A77F
CPU: i9 10980XE
tistou77
In fact it was not related to the cable, I had another "Check CPU" (1 time) 😄
What is this error ?
Thanks
Case: Lian Li A77F
CPU: i9 10980XE
cekeu
Level 12
it is always delicate a connection error at the first start.
From the first start of my card I connected the 2 8 pins dedicated to the cpu. I never had any startup problems.
For the oc I use the AI Overcloking and the xmp for the memories and I have no problems. My cpu is at 4.6 ghz every day with a custom EK cooling, I could set it to 4.8 for daily use but 4.6 ghz is enough for me. My cpu can be easily oc to 5.0 and above.
I do not use manual overcloking because I lack knowledge.
I hope you came across a card that was shipped from the factory and was not tampered with and sold.
As a Frenchman I recommend LDLC to buy.
