Results 1 to 3 of 3
    ROG Enthusiast Array
    Feb 2013
    12
    64
    Z490 ROG Bling RGB Bling Audio jacks - how to turn off?
    I want to turn off the audio jack RGBs which are these:
    https://imgur.com/86QyYA5
    They are too bright and reflect off the white wall behind my PC to create a giant circle of white light. It's like an experiment to prove that R+G+B = white but fails to do even that.
    https://imgur.com/AkqTb9h
    The options in the BIOS let me turn them off but also turns off all other functional LEDs like front panel indicators.
    https://imgur.com/4AOXsZG
    My motherboard is the Z490-I, BIOS is 0607.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    367
    8,334
    I'm not sure there is a separate option. Those are actually color coded to the standard jack color for PC audio hookups. Red for mic, Green for output, Blue for line in. If you aren't going to use them I would cover them with something opaque to block the light.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Feb 2013
    12
    64
    Thanks for the reply.
    Yes, I do not see any option but to cover them up with black tape.
Tags for this Thread
