Page 1 of 2 1 2 LastLast
Results 1 to 10 of 14
    New ROGer Array devourment_138 PC Specs
    MotherboardASUS ROG MAXIMUS XI EXTREME Motherboard
    ProcessorIntel Core i9-9900KS
    Memory (part number)F4-3200C14Q-32GTZR
    Graphics Card #1Nvidia 1080 TI
    Storage #1Samsung Evo Plus 2TB
    Storage #2Samsung Evo Plus 1TB
    CPU CoolerCorsair Hydro X custom loop
    CaseLian Li O11 Dynamic XL (ROG Certified) Aluminium Midi-Tower - Black
    Power SupplyCorsair HX 1000i
    OS Windows 10
    Jul 2020
    7
    Overlocking help - ROG MAXIMUS XI EXTREME and i9-9900ks
    Hi Guys,
    I am wondering if i am able to have some assistance trying to achieve an overclock on my system please?
    Ideally i would like to get a 5.1ghz all core on my CPU and i am no longer able to boot into Windows with XMP enabled. this used to work but i think the issue started happening since i upgraded my BIOS to 1502.
    if someone has some time to assist i would really appreciate it, i am quite new to Overclocking and am running into issues and seem to struggle to get things stable.
    i am thinking i would like to get my XMP working first and then try achieve the CPU OC?
    My parts are below:
    Case: Lian Li O11 Dynamic XL (ROG Certified) Aluminium Midi-Tower - Black
    Motherboard: ASUS ROG MAXIMUS XI EXTREME Motherboard
    CPU: Intel Core i9-9900KS Processor
    Memory: G.SKILL TridentZ RGB Series 32GB (4 x 8GB) 288-Pin DDR4 SDRAM DDR4 3200 (PC4 25600) Desktop Memory Model F4-3200C14Q-32GTZR
    PSU: Corsair HX 1000i
    Hard Drive: Samsung Evo Plus 2TB and 1TB NVME, also two Crucial SSDs for data storage and temp volumes)
    Video Card: Currently have a 1080 TI in here from out of my old Rig, i am waiting for the 3080 TI to come out and ill replace with that
    Cooling: Corsair Hydro X custom loop (my first water cooled build) Radiator Fans are 3x ML120 and case fans i have 7 LL120 Fans. bottom 3 are set as intake side 3 and rear fan are exhaust. prob would have had the side as 3 intake as well but i didnt want them in reverse because they just dont look as nice lol
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    499
    13,637
    Just use BIOS flashback method to 1402....1502 has many RAM kit problems...
    OS Windows 10
    Jul 2020
    7
    Hi Arne,
    I did a BIOS Flashback and i am now back on Version 1401.
    i have done some testing pre and post BIOS change.
    BIOS 1502 no OC
    Cinebench: 2052
    Realbench Max temp: 84 Min temp:36
    Downgraded to BIOS 1401
    XMP 1: - Crashed when trying to run Cinebench.
    XMP2
    Cinebench: 2109
    Realbench Max temp: Min Temp: - crashed
    Turned off XMP again. was able to successfully run Cinebench and Realbench fully and got similar results to when my BIOS was 1502 with a complete run through.
    Also note, i selected yes when i got the yes/no prompt when enabling XMP...
    any idea how i can make my PC stable with XMP??? id be keen to try dial in a 5.1ghz O.C for CPU as well but id rather get Memory XMP working and stable first.
    any help would be much apprecaited.
    OS Windows 10
    Jul 2020
    7
    any help guys?
    Apr 2012
    499
    13,637
    Try 1.36v for vcore at LLC5 for 5.1GHz and try 1.05v VCCIO and 1.1v VCCSA for the RAM.....you can also try....say....1.365v vor DRAM voltage
    Make sure long and short duration power package limit are set to their maximum (CPU power options)
    Make sure your pump and fans are ramping up on load properly....5.1 is pretty toasty
    ROG Guru: Orange Belt Array XYchromosone PC Specs
    MotherboardASUS Maximux XI Extreme [BIOS 1602]
    Processori9 9900KS
    Memory (part number)G.Skill Trident Z RGB CL17 3600MHz 32GB [4x8]
    Graphics Card #1ASUS ROG Strix Gaming GTX 1080Ti 11GB
    MonitorAOC AGON AG271QG 27" 144Hz [165Hz OC]
    Storage #12 X Samsung 970 Pro NVMe 1TB M.2 SSD [DIMM.2_1+ DIMM.2_2]
    Storage #2Samsung 850 Evo SSD 500GB SATA 3
    CPU CoolerThermaltake Floe Riing 360 Premium AIO
    CaseFractal Design Define R6 Black
    Power SupplyCorsair AX1600i
    Keyboard RAZER Blackwidow X Tournament Chroma
    Mouse RAZER Lancehead [ambidextrous] Chroma
    Headset Sennheiser RS165 Wireless
    Headset/Speakers Sennheiser CX 100 inner ear headphones
    OS Windows 10 Pro x64 + Ubuntu Studio 20.04
    Network RouterASUS DSL-AC68U
    XYchromosone's Avatar
    Dec 2015
    30
    328
    Have you tried the AI OC feature that comes with the Z390 chipset from ASUS ROG mobos? When I used it in both 1401 and 1502 the 1502 gave my Maximus XI Extreme about 5% better OC.
    If you press F11 in the UEFI the AI OC guide will come up and you can run the automatic AI OC feature from there. I suggest this because once your system has been scanned for its potential OC parameters, it will set those parameters and then you can see what % OC you can get and in the UEFI you can tell what multiplier you system is set to for "no load" and "under load", just to get an idea.
    Caution I am not certain if the AI OC feature utilises the XMP profile for your RAM, i think you can tell from the Main window in the UEFI? If it doesn't then you might be able to also set an XMP profile on top of the AI OC for experimentation, but i am not certain if this is doable or recommended, hence for caution. Hopefully a member with experience in this particular area can chime in.
  7. #7
    OS Windows 10
    Jul 2020
    7
    i did try but didn't seem to have much luck with that
  8. #8
    Processori9 9900KS
    Dec 2015
    30
    328
    so what happenned when you set up AI OC? Did the ROG Boot screen show any OC %? What is the best OC CPU multiplier and CPU/RAM voltage etc. are you able to achieve with a stable system? Did you try ARNE SAKNUSSEMM suggestions?
  9. #9
    OS Windows 10
    Jul 2020
    7
    Quote Originally Posted by XYchromosone View Post
    sorry for the delay in reply, i use my gaming PC as my work pc since recent events have me working from home so often testing or downtime isnt as quite as i would have liked.
    i was working with Arne via messages and tried all possible things with him, possibly faulty memory perhaps when i dont use XMP my system is stable and no issues as soon as XMP is enabled BSOD's either just when logging into Windows or during Realbench tests.
    i have tried 3 differnt BIOS version (currently on 1302, but also had 1401 and 1502 installed for testing)
    by memory when doing the AI OC this is similar to what i experience when enabling XMP.
    in my BIOS my cooler is given a score of 194
    also has the following
    non AVX V req for 5000 mhz is 1.221v
    AVX v req for 5000hmz 1.266v
    cache v req for 4300mhz is 1.118v
    then has next to it for max.
    MAX nonAVC stable 5129mhz
    max avx stable 4975 mhz
    max cache stable 4988 mhz
    i may as well put the latest BIOS version back on since that seems to have not been causing the issues or wait for ASUS to release a new one and hope for the best.
    i havent yet but tempted to OC the CPU and leave XMP off on my memory and see if that is stable?
    have started contact with g.skill around RMA for the memory to see if that is an option but that is a slow process by the looks of it..
  10. #10
    ROG Guru: Yellow Belt Array Carlyle2020 PC Specs
    Laptop (Model)amd4000 for sure next time
    MotherboardAsus Maximus XI APEX
    Processorgaming9900ks/@5.2 avx -1 / manual vcore 1.32/LLC5/AC+dc 0.01/TVB off/all power savings on
    Memory (part number)Corsair LPX 4000 CL19@16.17.28/300/2T/ 1.42 volt
    Graphics Card #1Gainward RTX 2080Triple/tempsense on Displayport needed
    Sound CardXonar STXII mods:3xLME 49720NA
    MonitorLG 38GL950G / -HDR / +madVR
    Storage #12TB 970evo plus nvme
    Storage #21TB 960evo nvme +2x 1tb evo 860 hw-sata-raid
    CPU Coolerarctic freezer II 280
    CaseV2-Silverstone FT2 dampened up the wazoo
    Power SupplySeasonic TX-850
    Keyboard Cherry KC 1000 on top of a cherry MX1 for ergonomics :)
    Mouse MX Master 3
    Headset Sennheiser PC360 + Philips X2HR
    Headset/Speakers A250 / cause LG was stingy
    OS Win 10 64bit
    Network Routeryeah right...
    Accessory #1 Silverstone EBA01 headphone stand / black
    Accessory #2 radio Keyfob to turn on and off
    Accessory #3 4 bay fantec /10tb red/+scrap
    Mar 2018
    17
    143
    trace centering on - should be tested
    vccsa 1.3 until stable - then lower it
    and switch the sticks around
    maximus tweak mode 2
    Rgds Carlyle
