Results 1 to 3 of 3
Thread: G75 VW help
    New ROGer Array
    Jul 2020
    6
    G75 VW help
    Hi, I've just acquired a second hand G75 VW, the previous owner changed the mobo, he has put a 3D board in replacing the old 2D and has it rigged via an external inverter board, can you tell me it the connection from a 2D monitor would fit to a 3D board please?
    Thanks.
    ROG Guru: Green Belt Array
    Nov 2012
    67
    719
    The 3D mobo has only connector for 3D display. It is different from 2D connector. The 3D mobo also has connection for the emitter which is required for 3D display. You also need the 3D glasses.
    G752VSK, G75VW-3D, G51J, G1S
    Homebuilt Windows Server
    New ROGer Array
    Jul 2020
    6
    Ah, damn, ok, thanks for the info, it saved me taking the laptop apart.
    Now to think, do I want to change the LCD or the mobo to make it look ok again?
    Thanks.
