Results 1 to 3 of 3
Thread: ROG SLI HB Bridge - Need Help
07-05-2020 10:48 PM #1
Megalamaniac PC Specs Motherboard Rampage VI Extreme Encore/Rampage V Edition 10 Processor Intel i9-7920x/Intel i7-6850k Memory (part number) 32g TridentZ RGB F4-3600C16Q/32g TridentZ F4-3200C14Q Graphics Card #1 GTX 1080ti Strix/GTX 970 Graphics Card #2 GTX 1080ti Strix/GTX 970 Graphics Card #3 none/GTX 970 Sound Card none/SB Recon3D PCIe Storage #1 Samsung EVO Plus 970 1TB/Samsung Evo 960 1Tb Case Thermaltake Core WP200/Coolermaster HAF 932 Power Supply Corsair AXi1500/Corsair AXi1200 Accessory #1 Aquaero 6 Pro, LT 6/Aquaero 5 Pro, LT 5 Accessory #2 Dual Loop Custom Watercooling
- Join Date
- Dec 2016
- Reputation
- 10
- Posts
- 22
I'm looking for the a ROG-SLI-HB-BRIDGE 3 Slot, specifically this one.
https://rog.asus.com/graphics-cards/...b-bridge-model
I currently have the 4-Slot version, but have upgraded my Motherboard and now need the 3-Slot.
I would also settle for the RGB cable as the one for my 4-slot has broken. The wires on the bridge end connector have started to break off.
Any help would be appreciated.
07-06-2020 10:10 PM #2
Super Gnome PC Specs Motherboard ROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula Processor Intel® Core™ i9-9980XE / AMD 3950x Memory (part number) Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH Graphics Card #1 Asus 2080 Turbo / Asus 2080 ti Turbo Graphics Card #2 Asus 2080 Turbo / Asus 2080 ti Turbo Monitor JAPANNEXT JN-VT500UHD 4K 50-inch LCD Storage #1 Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500 Storage #2 Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2 CPU Cooler ROG Ryujin 360 / NZXT Kraken X62 Case Thermaltake View 71 TG / Thermaltake View 31 Power Supply CORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2 Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 396
Have you tried Ebay? You can often find that kind of thing there, but it might not be right away.
07-07-2020 08:23 PM #3
- Join Date
- Dec 2016
- Reputation
- 10
- Posts
- 22
Yep, tried ebay and they have tons of non-RGB versions and I got one of those for the time being.
I found a 4-slot RGB HB Bridge on ebay Australia, but no 3-slot.
Pretty much looked everywhere I can think of and have only been able to find one. Problem is, it's at a PC store in Manila and I'm in the southern US and it's already kind of pricey without considering shipping.
