Results 1 to 2 of 2
    New ROGer Array
    Jun 2020
    1
    B360G gaming coil whine
    Hello,
    i have a problem. I started noticing that my PC was making this high pitched sound when moving my mouse around. I started investigating and found out that the CPU vrms are making this sound. When i disable the c-states in BIOS the problem is less noticeable. I tried a different PSU stil no luck. Is there anything i can do i tried to RMA the motherboard but my seller wont acknowledge this as a "serious" problem. Oh and my CPU is i5-9500.
    Thank you for answering in advance.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,688
    ***Moved from service inquries. MUST have existing RMA to post there***
    Hi Bostjan,
    Coil whine is not typically considered a defect by manufacturers, whether that be motherboard or GPU. It's just the nature of hardware. It's likely that any unit of that model will behave the same way in the same environment. I don't work for ASUS but I don't think coil whine is a valid reason. I doubt an RMA would help anyway because that would replace it with the same thing.
    If it's related to a USB device I would try a different USB port. If you already tried a different _model_ of PSU then it's too bad that didn't work. That would have been my first suggestion.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
Tags for this Thread
