Results 1 to 2 of 2
    ROG Guru: Yellow Belt Array Asryan PC Specs
    Asryan PC Specs
    MotherboardAsus Maximus Hero X
    Processor8086k / 5GHz / delidded
    Memory (part number)32GB G.SKILL Trident Z RGB / 3466Mhz
    Graphics Card #1GTX 1080 TI EVGA FTW3
    MonitorASUS PG34Q - 34" GSYNC
    Storage #1SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500Go
    Storage #2HDD: WD Green 2To 64Mo 3.5"
    CPU CoolerCorsair H150i + ML 120 Pro
    CasePhanteks Enthoo Luxe tempered glass
    Power SupplyCorsair RMI 850 GOLD
    Keyboard Corsair k70 rapidfire
    Mouse Logitech G900 Chaos Spectrum
    Headset Logitech G933
    Headset/Speakers G560 Logitech
    OS Win 10 60 bits
    Oct 2016
    14
    156
    Questions about AI SUITE
    Hi
    After an attempt on gigabyte motherboard I went back to Asus. Gigabyte software was hell, freezing computer and all kind of issues.
    I also got rid of all my Corsair devices because Icue is also a pain.
    I have some questions about AI SUITE.
    If I don't run the programm, the fan curve which are applied are the one in bios?
    i noticed that the temperatures were wrong and wayyy lower than the one in HWFINO
    Are the fan curves set up in bios more accurate?
    Thanks
    ROG Enthusiast Array GObonzo PC Specs
    GObonzo PC Specs
    MotherboardROG Strix Z370-E Gaming
    Processori7-8700K @5GHz
    Memory (part number)G.Skill F4-3200C14D-16GTZSW
    Graphics Card #1EVGA GTX 1080 Ti FTW3 GAMING
    MonitorMSI Optix MPG341CQRV (34" 3440x1440p)
    Storage #1SSDs: 5.25TB, M.2 NVMe: 512GB
    Storage #2external - HDs: 8TB
    CPU CoolerROG Ryujin 360
    CaseFractal Design Vector RS (5x be quiet! Silent Wings 3 140mm High-Speed PWM)
    Power Supplybe quiet! DARK POWER PRO 11 750W
    Keyboard Corsair K70 LUX RGB — CHERRY® MX RGB Brown
    Mouse LG G600, Corsair Vengeance M95
    Headset Corsair Void Surround
    OS Win10 x64 Pro
    GObonzo's Avatar
    Apr 2019
    44
    i've had some issues with AI Suite not registering certain fan hubs and not allowing PWM control to the fans connected. other times it would auto-implement DC settings for PWM fans connected directly to the motherboard and I would have to restart the system multiple times before it would detect them properly.
    when using the BIOS Qfan options they always seem to work perfectly.
    if not using any 3rd party fan control software, the BIOS fan settings will be implemented.
    i never trust any single software's temperature reading. some don't update as fast as others, some just give an average of all cores, some only the hottest or coolest core. i usually check a few different options like Core Temp, RTSS, motherboard control software like AI Suite, BIOS readings, etc and go for an average of all of them.
    ASUS Strix ROG Z370-E Gaming | i7-8700K \ ASUS ROG Ryujin 360 | G. Skill Trident Z 3200 CL14 2x 8GB | EVGA FTW3 1080 Ti | be quiet! Dark Power Pro 11 750w | M.2 480GB \ SSD: 5.25TB \ HDD: 8TB | Fractal Design Vector RS \ 5x be quiet! Silent Wings 3 140mm High-Speed PWM | MSI Optix MPG341CQRV | Logitech G600 | Corsair K70 LUX RGB | Xbox One S Gamepad | Corsair Void Surround
