Results 1 to 5 of 5
    New ROGer Array
    Jan 2019
    5
    Question DTS Custom on ASUS TUF Gaming x570 WiFi
    I just built a new system with an Asus Tuf X570 MB. I had two motherboards in my cart and went with the Tuf for the sole reason or tipping point was the DTS feature.
    After I fresh windows install I updated all the drivers from the Asus support page site. After some installing of game launcher I turned my focus to the DTS Custom app to try to set it up. after opening the app it locks up not taking a single button click just says please connect headset and my headset is connected. So i tried three or 4 headsets I had around Corsair, Logitech G series and Turtle beach and finally Steel series. Each one windows saw i was able to listen to but DTS custom would not see them or allow me to even click on any buttons. After several attempts to remove and install Audio drivers I noticed the DTS app was not un installing from the windows store and DTS custom could not be removed. So i cleaned DTS Custom up from the Registry deleted the files and rebooted several times and un installed and installed the official audio drivers. i then re downloaded the DTS custom from the windows store. Now it simply shows a welcome to DTS splash screen and once again i can not click on the ok or close or anything to get off this screen.
    I am a little annoyed as this was a feature I decided I wanted and i can't get it to work.
    Any suggestions or work arounds? Searches all point to getting the DTS app from the Asus site but I do not see it listed in Other downloads or even in audio drivers from the site. I really don't want to do a second fresh install yet again.
    ROG Guru: Orange Belt Array MoKiChU PC Specs
    MoKiChU PC Specs
    MotherboardASUS ROG Strix Z370-F Gaming
    ProcessorIntel Core i7-8700K
    Memory (part number)Corsair Vengeance RGB DDR4 2666MHz CL16 - 16GB (2 x 8GB)
    Graphics Card #1ASUS ROG Strix GTX 1080 Ti OC
    MonitorASUS ROG Strix XG35VQ
    Storage #1System : SSD Samsung 960 EVO 256GB
    Storage #2Games : SSD Corsair MP510 240GB | Data : SSHD Seagate 2TB
    CPU CoolerCooler Master ML240L RGB
    CaseBitFenix Enso
    Power SupplyCorsair TX850M (850W)
    Keyboard Logitech G413
    Mouse Logitech G502
    Mouse Pad PECHAM MPad-XXL
    Headset/Speakers Logitech Z333
    OS Windows 10 64 bit 20H2/VB/19042.x
    MoKiChU's Avatar
    Aug 2013
    225
    473
    Try with Realtek Audio Drivers (UAD - ASUS ROG/PRIME/TUF MB) from my UAD drivers thread. Follow scrupulously your INSTALL process with cleanup step, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
    Note (in order to choose correctly the install/update process to use) : You have a ASUS TUF DTS Custom motherboard.
    New ROGer Array
    Jan 2019
    5
    Thank you I'll try this tonight.
    New ROGer Array
    Jan 2019
    5
    Thanks I followed the excellent instructions and tried it twice and still same issue splash screen that says Tuf Gaming Content mode everything is greyed out nothing is clickable says please connect a Headphone to use DTS. I guess Sadly none of my headset are compatible even though I just DL the trial of DTS sound unbound and all 4 work there.
    ROG Enthusiast Array Dude1070 PC Specs
    Dude1070 PC Specs
    MotherboardROG Grosshair VII Hero
    ProcessorR9 3900X
    Memory (part number)16 GB G.SKILL TRIDENT Z 3600 F4-3600C15D-16GTZ
    Graphics Card #1MSI GAMING X GTX 1080 Ti
    Sound CardOnboard
    MonitorASUS V32AQ (2560X1440) DELL S2309W (1920x1080)
    Storage #1Samsung SSD 970 EVO+ 500GB
    Storage #2SSPC 1 TBS AMSUNG SSD EVO 850 500GB
    CPU CoolerLiquid Greezer II 240
    CaseThermaltake C36
    Power SupplyEVGA Supernova 850GS
    Keyboard Logitech G510s
    Mouse Logitech G502 Proteus Spectrum
    Headset Cerberus V2
    Headset/Speakers Logitech Z506 Surround Sound Home Theater Speakers
    OS W10 Pro X64
    Dude1070's Avatar
    Feb 2017
    42
    Quote Originally Posted by CoopII View Post
    Set the advanced setting in RCP like in this pic
Name:	realtek setting.PNG
    Then Unplug and replug the headset in the front panel jack.
