Results 1 to 5 of 5
    ROG Member Array itooth PC Specs
    itooth PC Specs
    MotherboardASUS Rampage IV Extreme
    Processori7-3970 CPU @ 305 GHz
    Memory (part number)Corsair 1333 (64 MB)
    Graphics Card #1NVIDA GeForce GTX Titan Hydro Copper 6.0
    Graphics Card #2NVIDA GeForce GTX Titan Hydro Copper 6.0
    Graphics Card #3NVIDA GeForce GTX Titan Hydro Copper 6.0
    Sound CardRelated High Definition
    MonitorASUS ROG PG278Q x3 (3 way SLI)
    Storage #1Samsung 869 Pro 1 TB SSD
    Storage #2WD 4.0 TB HDD in RAID 1
    CPU CoolerCustom water cooled system
    CaseCorsair 900
    Power SupplyCorsair AX 1200 watts
    Keyboard Corsair K95 RGB
    Mouse Corsair M95 Vengenance
    OS Windows 10 Pro
    Jan 2015
    5
    Exclamation Auto Boot will not function
    Hello all,
    I am not able to auto boot to Windows 10 when I start up my computer. It will go as far as AmericanMegaTrend window and then I am asked to hit F1 which takes me into the BIOS. All my settings seem correct and the boot order is correct. I can get to OS via force boot only. My BIOS is up to date.
    System: Rampage IV Extreme, BIOS 4901, Window 10 x64 O.S., SAMSUNG 860 Pro SSD, NIVDA GForce SLI x 3, Cosair 1333 RAM x 8 chips, RAID 1.
    Thank you!
    ROG Guru: Blue Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    750
    Here is the procedure for install of Windows 10 on NVMe drive.
    1 - Make sure you unplug all SATA and USB drives, the M.2 drive has to be the only drive installed.
    2 - Go into the bios, under the boot tab there is an option for CSM, make sure it is disabled.
    3 - Click on secure boot option below and make sure it is set to other OS, Not windows UEFI.
    4 - Click on key management and clear secure boot keys.
    5 - Insert a USB memory stick with a UEFI bootable ISO of Windows 10 on it.
    6 - Press F10 to save, exit and reboot.
    7 - Windows will now start installing to your NVMe drive as it has its own NVME driver built in.
    8 - When the PC reboots hit F2 to go back into the BIOS, you will see under boot priority that Windows boot manager now lists your NVMe drive.
    9 - Click on secure boot again but now set it to Windows UEFI mode.
    10 - Click on key management and install default secure boot keys
    11 - Press F10 to save and exit and windows will finish the installation.
    Once you have Windows up and running, shutdown the PC and reconnect your other SATA drives.
    itooth PC Specs
    CaseCorsair 900
    OS Windows 10 Pro
    Jan 2015
    5
    RedSector73,
    I performed the steps that you listed, but unfortunately that did not solve my issue. The only way I can boot to OS if via a "force boot" option.
    itooth PC Specs
    CaseCorsair 900
    OS Windows 10 Pro
    Jan 2015
    5
    Asus, support has not been much help either. Last suggestion from them was the clear my CMOS. If I do that will I have to re-download to the most up to date BIOS?
    itooth PC Specs
    CaseCorsair 900
    OS Windows 10 Pro
    Jan 2015
    5
    I believe I found the solution to the boot up problem.
    My system in water cooled and the setting to monitor the fan speed to the the CPU was set to monitor. However, I do not have a CPU fan, as I have a water block over the CPU. So my system thinks that this is a problem and will not auto boot.
    I turned off the CPU fan monitoring setting to disable or ignore. Then saved setting and exited the BIOS. System then auto booted to OS.
    You may want to note this for other users of water cooling systems.
    I believe this was a protection setting and had to be manually overridden to get past it.
