Results 1 to 7 of 7
    New ROGer Array
    Jul 2020
    2
    Question [Z490-I] Turn-off audio jack LEDs
    Hi all,
    I just bought a Z490-I motherboard and I'm very happy of it but I don't managed to turn-off audio jack LEDs located behind the MB (see picture)
    I'm using my monitor's sound output hence it's projecting a big halo on the wall
    I've searched in the BIOS settings and the Armoury crate software without success
    I managed to turn all LEDs on the MB except for these ones
    Did I miss something?
    Any help would be appreciated :-)
    ROG Member Array
    Jun 2020
    7
    This was asked not too long ago, don't think its possible for this particular motherboard.
    https://rog.asus.com/forum/showthrea...ow-to-turn-off
    New ROGer Array
    Jul 2020
    2
    Quote Originally Posted by pained View Post
    Arghh... that's not ideal...
    I guess I will buy some headphone connectors or salvage old ones to plug them, it would be better than black tape
    Thanks for pointing me to the other thread.
    ROG Member Array
    Jun 2020
    22
    You could also look for a "dust cover", which are readily available on Amazon. I'm considering that myself since I have an external USB DAC and use my front panel microphone jack...
    https://www.amazon.com/s?k=3.5mm+dus...f=nb_sb_noss_2
    ROG Enthusiast Array
    Feb 2013
    12
    65
    Quote Originally Posted by morello1n View Post
    I've been searching for something of this sort for a few days now. What I am unsure about is whether these sort of plugs activate the audio jack detection switches.
    From https://www.amazon.com/Black-3-5mm-H...633662&sr=8-18
    Feb 2013
    12
    65
    I found an easy solution.
    I'd bought Noctua's Anti-vibration nails for mounting fans to PC cases. I hate threading screws into the unthreaded plastic of any case fan. So, I always use these anti-vibration nails. https://www.amazon.sg/gp/product/B07...?ie=UTF8&psc=1
    So, I cut down the unused ones and just repurposed them as anti-dust plugs. Cheers.
    EDIT: And I can confirm they do not activate the internal audio jack detection switches. Nor do they get hot and melt.
  7. #7
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Intel NUC laptop LAPQC71D
    MotherboardROG Crosshair VIII Dark Hero
    ProcessorAMD 5800X
    Memory (part number)32GB G.Skill Ripjaws V 3600
    Graphics Card #1ROG Strix RTX3090Ti
    Sound CardSound Blaster Z
    MonitorAORUS FV43U
    Storage #1Samsung 970 Pro 512GB
    CPU CoolerCustom loop
    CaseBeQuiet Dark Base Pro 900 V2
    Power SupplyCorsair HX1000
    Keyboard ROG Strix Flare II Animate
    Mouse ROG Chakram X
    Headset Steelseries Arctis Pro Wireless
    Mouse Pad ROG Scabbard
    Headset/Speakers Logitech z906 5.1
    Network RouterpfSense/OPNsense
    xeromist's Avatar
    Jul 2010
    436
    8,540
    Great solution! Better than gummy tape residue.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
