Results 1 to 7 of 7
    ROG Enthusiast Array
    Dec 2013
    35
    My aimesh network keeps adding nodes
    I have a router network consisting in and GT-AC5300 as the main router and a RT-AC86U, GT-AC2900 and RT-AC68U as aimesh nodes. The last two had always been the most "troublesome" in the aimesh network but it had been working decently until I did an update a couple months ago.
    Since then the network has been very unstable particularly in the GT-AC2900 and RT-AC68U. Moreover, nodes keep apearing in my network. Some are refered as eth5, eth6, others have mac address as name, some even appear to have a hardware sofware version... Several firmware upgrades have come up since then but the same issues persist.
    At this point I am planning to reset all the routers and pair them again via the aimesh. I have always performed a standard update using the configuration website but I see people are very careful and follow very complicate (at least for me) upgrade rituals.
    My RT-AC86U, GT-AC2900 and RT-AC68U are displaying new firmware version and I would love to hear your advice on how to proceed. Thanks
    ROG Guru: Yellow Belt Array ahfoo's Avatar
    Jan 2020
    195
    Quote Originally Posted by Delosari View Post
    You may try this,
    1. break up all nodes and install the new firmware to individual one by one. Once install, hard reset your node .
    2. Pair the node one by one to the newly upgrade mesh node to monitor if it work correctly.
    3. If, the node not giving you problems, go on next node. If it is, post the log here.
    4. I do agreed the logging from asus router quite primitive and not easy to understand. But with little piece by piece of info hopefully we are able to solve the puzzle.
    PS: Remember to do a proper hard reset, and not to use the reset button on the router. Please refer to the following link for proper hard reset.
    https://www.asus.com/support/FAQ/1039074/
    hope it helped.
    ROG Guru: White Belt Array
    Apr 2020
    32
    84
    Hi
    Please use the feedback function in administration, we can check logs, and also provide your email to me in private message, we can query your feedback logs from our server.
    Thanks.
    Dec 2013
    35
    Quote Originally Posted by ahfoo View Post
    You may try this,
    hope it helped.
    Thank you very much for your reply. Today, I followed your steps and, so far, in the past 6 hours no "phantom" nodes have appeared in the network map. The RT-AC68U disconnected once but it came back on its own. I wonder if I could have your opinion on two doubts I have always had on my aimesh network:
    1) I have the impression that devices cannot find or connect to the aimesh router 5G network. In my case this is the GT-AC5300. Instead they connect to the weaker 5G network from further away nodes. Why would this be? In contrast, all the nodes seem to favour a direct connection to the aimesh router via 5G even if this is not the "best" option. For example, I would like my AC68U to connect to the AC86U via 2.4G since it is the closest, but still, there is a very thick stone wall between them. Is there a way to "suggest" the connection between devices/routers?
    2) Are there some aimesh parameters I should change in the router configuration website?
    Thanks again for all the help.
    Dec 2013
    35
    Quote Originally Posted by wilsondenq View Post
    Hi
    Thanks.
    Thank you very much for this reply. Actually, I had never heard of this feature and I shall use it in the future.
    Also, If I may, I have read on the forum some discussions on how some firmware upgrades impact the routers CPU performance. But, how do you check their workload on the routers website?
    Jan 2020
    195
    For question 1. The mesh node connect to the main router using 5GHz_1 of your AC5300 as 5 GHz consider wider spectrum than 2.4GHz. If you connect your mesh node via wired, your 5 GHz will become the your network backhaul.
    For question 2. From my understanding of aimesh system. All paremeter are set in the backend of your router. So there is not much you can set to it.
  7. #7
    Jan 2020
    195
    I did wrote to ASUS to add in feature to ROG router able to access device connected to nodes logging many times or at least device connected speed connected to individual node but no reply from them. If this option was able to coded into the firmware, user will be able to determine the problems if device not connected, node system down and connection speed.
Tags for this Thread
