01-05-201108:44 AM - last edited on 03-05-202408:30 PM by ROGBot
Hello people i am experiencing some weird stuff since i bought my G73JH i have in some games (SC2 and MASS EFECT) this problesm with crazy pixels being black, like the rende isn`t there i made a video with MASS EFECT
i played a few games on my Note, but only new games have this, ex War Craft 3 runs perfectly
HERE IS THE VIDEO - look at shepard on the Chr Create time
I did hear the latest drivers cause like shadow issues with SC2 and such. You may want to download the older 10.10 mobile drivers and give those a shot just to see if it is driver related.
Hmm. Not sure but from the looks it could be your GPU is well "bad". It has the same artifacts that most GPU's get when overclocked a bit. I would suggest underclocking it a bit to see but it may be a bit technical. I would probably talk to ASUS about getting an RMA and GPU replacement. If the underclocking worked then it would just confirm the problem and still warrant an RMA for a new card since it should run perfectly at stock settings...
Just to check can you run a GPU-Z And tell us what the Core/Memory clock speeds are set too? (There will be current and default ones. Current may be reading slow in windows since it downclocks when not under load, but the default values would tell us what it shoots up to.)
