Results 1 to 2 of 2
    New ROGer Array
    Jul 2019
    2
    GL704GM dual monitor setup question
    hi guys.. I am trying to set up dual monitor for my laptop (ASUS ROG Strix Scar II GL704GM) but encountering issue's, sorry if this is the wrong board
    the problem is that I can only use extended monitor, not like when on PC I can seperate the screens and they're like their own individual screen.. or is that how laptop dual screens work..?
    also my monitor's resolution can't go to 1920x1080 like my laptop so it's ugly... do I need to buy a better monitor?
    Thanks guys and yeah if it's the wrong board if u can point me in the right direction, thanks for your time
    Super Moderator Array
    Jan 2013
    100
    2,226
    Not sure if you mean you are seeing duplicate displays or the same thing on your external monitor, but either way, you can just go to the settings to choose if you want your external monitor to duplicate or 'extend' (show a different screen or second screen) your notebook screen.
    There are shortcuts and different ways to do the same thing, but since Microsoft's website has information about it, will just provide their link below if you want to take a look.
    https://support.microsoft.com/en-us/...-dual-monitors
    As far as your external monitor resolution goes, you may want to check the specs to make sure it is not a settings problem, or if you refer to the link above for Microsoft's website, you can see in the picture that there is a setting to adjust your monitor resolution in the same area if you want to check it.
    It's not mentioned or seen on that page, but you should see pictures of both your monitors in that same area as well and you can left-click either picture of the monitor to change the settings for each corresponding display.
