mixing different RAM speed and latency on Crosshair Hero VIII,will it boot?
frozen_sun
Hi.Sadly I couldn't find same memory speed and latency.
I have 2x8GB of 3200MHz CL 16 and 2x8GB of 3600MHz CL 18.
So i wonder if I install all 32gigs,could I have any possible issues,which kind and how to resolve them?
All modules are Corsair Vengeance Pro RGB.
4 REPLIES 4
kkn
Level 14
dont listen to arne, he dont know what hes talking about.
best advice it to not mix diffrent ram on intel boards, you could get away with it on amd before that i know of.
best is to get a new kit of ram at the speed and size you want , and try and sell the ones you have (if they are in good working condittion ) on the bay unless you can use them some where else.
Yeah that bloke is a looney 😮
Anyway...someone else to listen to
https://rog.asus.com/forum/showthread.php?57038-Don%92t-combine-memory-kits!-The-meat-and-potatoes-o...
frozen_sun
I thought AMD is more sensitive to different latency and speed.
I'm on AMD.
