Results 1 to 1 of 1
Thread: AI Suite 3 Fan Control
07-17-2020 11:00 PM #1
Super Gnome PC Specs Motherboard ROG Rampage VI Extreme Omega / ROG Crosshair VIII Formula Processor Intel® Core™ i9-9980XE / AMD 3950x Memory (part number) Corsair LPX Vengeance DDR4 2666MHz 128 GB / Corsair Vengeance LPX 32GB DDR4-3200 32GB DDR4 3200MH Graphics Card #1 Asus 2080 Turbo / Asus 2080 ti Turbo Graphics Card #2 Asus 2080 Turbo / Asus 2080 ti Turbo Monitor JAPANNEXT JN-VT500UHD 4K 50-inch LCD Storage #1 Crucial MX500 1 TB / Sabient SB-ROCKET-NVMe4-500 Storage #2 Samsung 970 Pro 1 TB / ADATA XPG SX5500 Pro 3D NAND NVMe Gen3x4 PCIe M.2 CPU Cooler ROG Ryujin 360 / NZXT Kraken X62 Case Thermaltake View 71 TG / Thermaltake View 31 Power Supply CORSAIR AXi Series, AX1600i 1600 watt / Thermaltake Toughpower iRGB 1200 watt Accessory #1 Noctua 140mm 3000 RPM x 4 / Noctua 140 mm 3000 RPM x 2 Accessory #2 Gigabyte GC-A 2WAY NVLINK RGB (3-slot) / ROG NVLINK Bridge 3-Slot A
- Join Date
- Mar 2019
- Reputation
- 28
- Posts
- 396
After a Windows reinstall, I made the unfortunate mistake of believing AI Suite 3 would again properly control the fans so I installed it. Instead AI Suite Fan Xpert just had the fans blast away almost out of control, so I just gave up after it no longer worked as it used to and nothing seemed to help and the fans would just blast away no matter what the settings were. That meant uninstalling and controlling from the Bios. That worked fine, but now those files from AI Suite 3 are still there despite uninstalling. Worse yet is that those AI Suite 3 files are still controlling the fans despite an AI Suite 3 uninstall. What it means is I have to restart and go into the BIos and then all is good. But starting and restarting and going to the Bios every day is a hassle.
There is an AI Suite 3 cleaner that Raja posted but it simply does not work. Can you just manually delete the Asus FanControlService File? Anyone?
Edit: Solution: Reinstall Windows (again) and DO NOT install AI Suite 3 (ever again, lol).
Thanks in advance for any help or thoughts. I'd forgotten Asus software is cancer.Last edited by Super Gnome; 07-18-2020 at 02:38 AM.
