Results 1 to 6 of 6
    ROG Guru: Yellow Belt Array martine-dee PC Specs
    MotherboardAsus ROG Maximus XII Extreme
    ProcessorIntel Core i9-10900K @ 2GHz - 5.2GHz, NB 1.7-4.7 GHz
    Memory (part number)G.Skill F4-4000C15Q-32GTZR @ 3700 MHz CL14
    Graphics Card #1Asus GeForce GTX 1080 Ti Strix Gaming, 11 GB VRAM
    Sound CardCreative Sound Blaster AE-9
    MonitorAsus ROG Swift 360Hz PG259QN
    Storage #12x Samsung SSD 860 EVO 1TB
    Storage #21x WD Blue SSD 1TB, 1x WD Red HDD 1TB
    CPU CoolerCorsair Hydro Series H115i RGB Platinum
    CaseTT View 91 Tempered Glass RGB Edition
    Power SupplyCorsair AX1600i
    Keyboard SteelSeries Apex 7, Red
    Mouse Logitech G403 Prodigy Gaming Mouse @ 3200 dpi
    Headset Trust Gaming GXT 444 Wayman Pro Gaming Headset
    Mouse Pad Logitech G440
    Headset/Speakers Creative Inspire T6300 @ AE-9
    OS Win 10 Pro 64bit 2004, Ubuntu 16.04
    Accessory #1 Creative SB AE-9's ACM
    Accessory #2 4x TT Riing Plus RGB 140 mm, 3x TT Pure Plus RGB 140 mm
    Accessory #3 Thermaktake Pure 20 Argb Sync 200 mm
    martine-dee's Avatar
    Sep 2017
    50
    144
    Max XII Extreme - Does the Thunderbolt take PCIe lanes
    I come here with a MAX XII question. I realize those are Max X/XI forums, but I haven't found a better match for Max XII atm. :/
    So, I am new to Maximus, and new to Thunderbolt. In reviews, I saw that the Max XII Extreme comes with a Thunderbolt 3 card. Well, cute, I never used it, probably never will have the need, but since it is there and boosts up the price tag so much, I wonder how it would work.
    Particularly, I would like to keep the x16 for the card, and the PCIe pins on Thunderbolt card look to me like using it would mean the x8/x8 mobo mode. [ The manual ] is not explicit about this, thus it is probably generally known.
    So... is there a way to utilize this included Thunderbolt 3 card while keeping the video card at x16?
    Thanks!
    A Quaker here
    New ROGer Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardCreative Labs Sound Blaster AE-9
    MonitorSamsung 32" UH750 QLED UHD Monitor
    Storage #1Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerCooler Master MLX-D36M-A20PC-R1 w/ Noctua NF-F12 industrialPPC-2000 IP67 PWM x3 Fans
    CaseLian Li PC-011 Dynamic XL (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad Razer Vespula V2 Mousepad
    Headset/Speakers Creative GigaWorks T40 Series II
    OS Windows 10 Pro for Workstations
    Network RouterROG Rapture GT-AC5300
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 Logitech BRIO ULTRA HD PRO WEBCAM
    Jesseinsf's Avatar
    Mar 2019
    22
    218
    It uses the Z370/Z390/Z490 chipset, so it will not affect your graphics card at all. Here is the issue though. The Z370/Z390/Z490 chipset does have 24 PCIe internal lanes. But it can only communicate and send data to and from the CPU/Memory at PCIe 4X speeds. If you have a Samsung 970 pro and a Thunderbolt card then you are already bottlenecking the heck out of the chipset's bandwidth to the CPU/Memory (especially if you are connecting a display to the Thunderbolt card). This will negatively affect all other data peripherals like WiFi, LAN, Sata drives and many things connected to the USB ports
    A note from the Specifications page:
    *1 PCIEx4 slot shares bandwidth with SATA6G_56 and PCIEx4 slot is default set at x2 mode. Please adjust BIOS settings to enable Thunderbolt card.
    Sep 2017
    50
    144
    Thanks! I've caught up a bit later with the Z490 architecture.
    A cool thing about this x4 slot is that I can use it for my AE-9, which only needs one PCIe lane. Then the graphics card can remain at x16.
    Plugging the M.2 SSDs via DIMM.2 will set the graphics card to x8 from what I've seen.
    A Quaker here
    ROG Guru: Yellow Belt Array btrach144 PC Specs
    btrach144 PC Specs
    MotherboardASUS Maximus XII Extreme
    ProcessorIntel i9 10900K @ 5.1 GHz
    Memory (part number)32 GB G.Skill DDR4 4000MHz C17
    Graphics Card #1EVGA 2080Ti FTW3 Hydro Copper
    MonitorASUS PG27UQ
    Storage #1x2 Samsung 970 Pro 1 TB in RAID 0
    Storage #2Samsung EVO 850 1 TB
    CPU CoolerCustom EK loop
    CaseCorsair 750D
    Power SupplyROG THOR 1,200W
    Keyboard Logitech G915
    Mouse Logitech G903 PowerPlay
    Headset Logitech G935
    Mouse Pad Logitech Powerplay
    Headset/Speakers Logitech Z905 5.1 surround
    OS Windows 10 (2004)
    Network RouterASUS AX11000
    Jun 2014
    140
    Quote Originally Posted by martine-dee View Post
    Yep, that's right. I use the motherboard slots for my 970 Pro RAID 0. The DIMM card is a cool idea but I hate that it drops my 2080Ti to x8.
    I know most people say x8 won't bottleneck a 2080Ti by more than 5% but I'm gaming at 4K 144Hz and need every FPS that I can get.
    Sep 2017
    50
    144
    Yeah, i resisted for long going down the Maximus lane, out of scare that it only has x16 for the graphics card and that's it. It is serendipitous that AE-9 can work without affecting the x16 for the graphics card. Also, it is great that I didn't order any M.2 drives for this PC. SATA SSDs will have to make due.
    A Quaker here
    Jesseinsf PC Specs
    Jesseinsf's Avatar
    Mar 2019
    22
    218
    Just remember the Chipset can handle up to 24 lanes, but can only output 4 lanes to the CPU/Memory. The 4X slots uses the Chipset, so does everything you plug in to the USB, LAN, Wi-Fi, the 3rd PCIe X16 slot. This means that it is easy to cause a bottleneck in performance through the chipset (Excluding the graphics card and DIMM.2). Graphics card and DIMM.2 are on a separate direct 16X link to the processor and memory.
