Results 1 to 4 of 4
    New ROGer Array
    Nov 2018
    9
    Strix GL503GE 2000RPM Fan problem
    Hello,
    My laptop's fans (CPU & GPU) run at 2000 rpm in minimum load case, even on idle, causing an annoying noise.
    Any help to reduce the fan speed on idle.
    Miniatura de Adjuntos Miniatura de Adjuntos Annotation 2020-07-22 025335.jpg
    Moderator Array
    Feb 2019
    13
    446
    Hello Sary,
    Are you able to switch mode to silent mode?
    New ROGer Array
    Nov 2018
    9
    Hello,
    Thank you for your reply.
    This is the working state of my laptop:
    Fan overboost : silent
    Cpu is running at 1.2GHz - 3% with turboboost disabled
    Power mode (on battery): Battery saver is on
    however, the fan speed is 2000rpm
    Any help please ??
    Moderator Array
    Feb 2019
    13
    446
    Hello Sary,
    Well...this is pretty normal for a gaming laptop with those specifications.
    We don't want the device to overheat and burn out, right?
    Please kindly understand.
