Results 1 to 3 of 3
    New ROGer Array
    Jul 2020
    2
    Cool What is the OC sweet spot for AMD Ryzen 3950x | X570 | AIO cooler. I'm at 4.275
    I've used the standard Dual Intelligent Processor 5 to overclock my PC.
    What is the sweet spot for this spec pc. Don't want to push too hard (reduce the lifespan), but don't want it lower than its potential.
    Thank you all
    I'm quite new to this.
    CPU AMD Ryzen 9 3950X
    CPU Cooling Cooler Master MasterLiquid ML360R
    Motherboard ASUS ROG Strix X570-E Gaming MB
    Graphics ASUS ROG Strix GeForce RTX 2080 Ti OC Edition
    Memory G.Skill Trident Z RGB 32GB (2x16GB), PC4-25600 (3200MHz) DDR4, 16-18-18-38, 1.35v, Dual Channel Kit,
    SSD WD 1TB SSD, WD Blue SN550, M.2 2280 NVMe PCIe Gen3
    Power Supply Corsair 750W RM750x (2018) Gold Power Supply, 80 PLUS Gold, 140mm Fan
    Case Fans Cooler Master MasterFan MF120R ARGB 3in1 Kit, includes 3x 120mm Fan, mini RGB Controller
    ROG Guru: Grand Master Array Arne Saknussemm PC Specs
    Laptop (Model)Laptop?...No way! (Model?...Jun Amaki...yes way!)
    MotherboardROG ZENITH II EXTREME
    ProcessorTHREADRIPPER 3960X
    Memory (part number)TXBD48G4000HC18FBK
    Graphics Card #1GTX Titan X
    Graphics Card #2SLI is dead to me
    Graphics Card #3Tri SLI is even dead to Nvidia
    Graphics Card #4Quad SLI is dead to everybody especially my credit card
    Sound CardXonar Essence STX
    MonitorASUS ROG Swift PG279Q
    Storage #1Samsung 970/960/950 PRO
    Storage #22x OCZ VERTEX 3/2x WD Caviar Black 500GB / 2x WD RED 2TB/Samsung 1TBSSDs
    CPU CoolerCustom Loop: Dual D5s, Dual Alphacool Monsta 480s, XSPC Raystorm Neo TR4, EK TitanX WaterBlock
    CaseNope!...Dimastech Easy XL...let it all hang out man!
    Power SupplySeasonic 1000 Platinum
    Keyboard Corsair Strafe MK2 ROG Claymore... or Fender Rhodes Electric Piano (MKI 73)
    Mouse Corsair M65Pro or Speedy Gonzalez...not Mickey...don't do Disney!
    Headset ...firmly on neck
    Mouse Pad Mouse don't got his own pad man...lives with me
    Headset/Speakers Edifier Spinnaker...or you mean the speakers in my head...man too many voices to name them all
    OS Win XP, 7, 8, 8.1 and Windows 10 Spyware Edition
    Network Router56k modem
    Accessory #1 Umm...nice tie?
    Accessory #2 Err...belt?
    Accessory #3 3 accessories?! I'm not a girl!!
    Arne Saknussemm's Avatar
    Apr 2012
    505
    13,670
    4.2 all core usually gives semi decent temps on AIO...but really for most things they are better left at stock with PBO settings maxed out and the CPU will cycle the cores at higher boost speeds.
    All core OC only really worth it for continuous render loads
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    127
    1,936
    Unless using Per CCX, as mentioned above auto values with PBO enabled is the best alternative. Like with any CPU your mileage varies depending on sample.
    Mine is 44/44/43/43 @ 1.33v. Of course, this also depends on your cooling solution, too.
Tags for this Thread
