Results 1 to 8 of 8
    ROG Member Array
    Nov 2019
    6
    GX701LXS - 'enter' key and '\' key are not working properly - [RESOLVED]
    I am using GX701LXS.
    When I set up the light for 'enter', '\' key lights up. If I set up light for the '\' key, the 'enter' key lights up. It seems like the order of the 2 keys is wrong in aura creator. I am wonderring if it is the software issue. I bought it 2 weeks ago, if it is the keyboard issue, I may return the unit to my retailer. Please let me know if you have the same problem.
    New ROGer Array
    Jul 2020
    1
    Update: It also happened on the Armoury Crate preset effects. If I select 'Laser' effect, I can see the same issue when I press the 'enter' and '\'. It is clear that it also happened on the Armoury Crate. I asked other users online and confirmed that some GX701 (2020 model) users had the same issue. And even the gx701 (2019 model) users also had the same issue. I am confused if it only happens on some of the devices. If it is a common issue, why ROG not fix it last year because it had happened on the previous generation?
    ROG Member Array
    Nov 2019
    6
    It is a common issue now. I got a new replacement from my reseller. Same issue. Please update the software to fix it.
    Administrator Array MasterC@ROG's Avatar
    Aug 2014
    121
    1,876
    We will investigate, thanks for bring it to our attention. Please double-check the Aura Creator version you have installed and reply. Thanks.
    ROG Member Array
    Nov 2019
    6
    Quote Originally Posted by MasterC@ASUS View Post
    My version is 3.0.4.0. A few days ago, ASUS released a hotfix for its keyboard. This issue doen't happen on Armoury Crate anymore. However, the 2 keys stopped working in ASUS Creator. I think ASUS only fix it via its own software. The ASUS Creator also needs an update. Thanks.
    ROG Member Array
    Nov 2019
    6
    Sorry, my creator vision is 2.0.3. '3.0.4.0' was the Armoury Crate version.
  7. #7
    Aug 2014
    121
    1,876
    Please go to Update Center and update AURA Kit to 20200909.
  8. #8
    ROG Member Array
    Nov 2019
    6
    All good now. Thanks
