Results 1 to 2 of 2
    ROG Enthusiast Array Nemesis158 PC Specs
    Nemesis158 PC Specs
    MotherboardROG B550-F Gaming
    ProcessorRyzen 9 3900XT
    Memory (part number)G.Skill 32GB 3600MHz
    Graphics Card #1EVGA RTX 2080
    MonitorLG 24GM77 144Hz
    Storage #1WD Black SN750 1TB
    Storage #2Samsung 960 Pro 1TB
    CPU CoolerNoctua NH-D14
    Casebe Quiet! Dark Base 700
    Power SupplyNZXT Hale90 1KW
    Keyboard Corsair K95 RGB
    Mouse Logitech G502
    Headset Steelseries
    Headset/Speakers Philips MMS430 with External AMP
    OS Windows 10 Pro v2004
    Network RouterMikrotik hEX RB750Gr3
    Jun 2012
    30
    Why are Armory Crate's RGB animations worse than Aura Sync's?
    I just built a New PC with a ROG B550-F Motherboard.
    After my experience with two previous ASUS RGB capable motherboards (Prime X370-Pro and Prime X470-Pro) I was seriously considering going with a different brand motherboard because ASUS RGB Software, Be it Aura Sync or Armory crate, Have always had some bug or other that just made them never work 100%.
    At the end of the day the ROG B550-F had the features and layout that work the best for what i wanted and my case.
    I have a be Quiet Dark Base 700 Case which has exterior RGB accents, which look totally awesome with a aqua color in the "breathing" effect.
    now before i go any further, as i understand it most lighting systems like this use PWM instead of direct voltage control to alter the brightness of individual LEDs or color banks, as it is much cheaper to implement.
    Using Aura Sync the Breathing preset doesn't have an adjustable speed but the PWM Step changes are frequent enough that the animation is smooth and it looks quite nice.
    when I have tried using Armory Crate before I notice a drastic difference (decrease) in PWM Step change frequency, that for me completely ruins the look of the breathing effect. Armory crate does enable selection of different speeds for the Breathing effect but the " jitter" that the decrease in PWM step change frequency causes is noticeable at all speeds.I previously had a ROG STRIX 1080TI and the difference was even more noticeable on the card than on the MB.
    I tried Armory Crate again on the new motherboard and made sure everything was up to date, and this (issue?) still exists.
    Now i try to uninstall armory crate and it leaves a bunch of garbage behind that interferes with Aura Sync where i have to end the Lighting Service process to get my RGB to work properly at all (the animation jumps and skips if i don't).
    Pick one program and get some actual professional software developers working on it Please. At the very least can something be done about the PWM Step change frequency to the effects in Armory Crate???
    P.S. I was also so disappointed when Aura Creator was finally released and it turned out that it doesn't let us make our own animation effects, just sequences between different RGB components using the existing ones provided.....
    Banned Array
    Jul 2015
    12
    96
    I have different experience cos you can set the amount of lights per strip so the effect will scale properly like full rainbow effect balanced across each fan led strip vs scaled up to only show 2 shades, defiantly think armoury crates need more improvements right now more customization something that is very much lacking right now
Tags for this Thread
