Results 1 to 4 of 4
    New ROGer Array
    Jul 2020
    5
    Dram channel bandwidth
    Hi, I'm new to tweaking pc settings and what not. I am having trouble understanding the mobo ram compatibility. I have the rog strix x570-e and Model F4-3600C16D-32GTZNC (2x16) ram, not until researching more after the fact i realized the mobo is rated for max 2333 mhz before oc. Now my question is whether or not running a dual channel means that its a max of 4666 mhz. Is setting the frequency to 3600mhz oc or is the that split between each channel and therefore meaning im not oc?
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    309
    7,699
    Channel count doesn't dictate speed rating. Dual and triple channel kits get the same rating as a single stick. And any speed above default is an overclock. That said, high speed memory is pretty common and relatively easy to set via XMP (intel) or DOCP (amd). It's not guaranteed though so you may find your combination of hardware can only run a 3600 kit at 3200 stable. You just have to try it.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    New ROGer Array
    Jul 2020
    5
    Thanks for your help! Also do you think I would benefit at all from adding another 2 sticks?
    xeromist PC Specs
    ProcessorAMD 2600X
    CPU CoolerWraith
    xeromist's Avatar
    Jul 2010
    309
    7,699
    Not unless you need the capacity.
