Asus rog g750jy drivers help
Bogdan_Schiau
Hello, I have an ASUS ROG G750JY and I would like to install windows 10 but I can't find the drivers for it. The most recent drivers are for 8.1x64.
Is there any possibility to find drivers for windows 10x64 for this model?
This is the specification of the laptop:
Processor: 4720HQ
Motherboard: ASUS G750JYA
Chipset:Intel® HM87 Express Chipset
Memory: 24G DDR3
Graphic Card: NVIDIA® GeForce® GTX980M 8GB GDDR5
Storage: 1TB HDD 7200 RPM With 256 G SSD
THE LINKS BELOW ARE THE SPECIFICATION AND SUPPORT FOR IT.
https://www.asus.com/ca-en/ROG-Republic-Of-Gamers/ROG-G750JY/specifications/
https://www.asus.com/supportonly/G750JY/HelpDesk_download/
I WOULD APPRECIATE IF SOMEONE COULD HELP ME.
5 REPLIES 5
toronto699
I Installed W10 Through Windows Update With No Issues On My G751JY , The 8.1 Drivers Work Fine On My G751 JY With Windows 10 Version 2004 ,
Blake1
Hello Bogdan,
I'm sorry that the device is not designed to use Windows 10, so we don't have the verified drivers on our website.
You may search on open platform or supplier's website to find more.
If the device is not designed to use Windows 10 how is it possible that other devices like ROG G750JX and ROG G750JZ have windows 10 drivers?
The ASUS ROG G750JY has superior hardware compared to those mentioned before but unlike the other two it does not hawe the verified drivers on your website.
I wonder if you really care at least a little about your customers? If you tell me in the first reply "You may search on open platform or supplier's website to find more"
I'm really disappointed.:mad:
I would like at least a more competent answer if possible.
MoKiChU
Level 40
You need these drivers for your notebook (for all other drivers, use Windows Update) :
[DRIVERS] Intel Chipset/MEI/SATA (6x/7x/8x/9x)
- Intel Chipset Drivers
- Intel MEI Drivers (Drivers Only) :
Drivers - 8x/9x
- Intel SATA AHCI-RAID Drivers (Drivers Only) :
Drivers - 8x/9x (AHCI Only)
[DRIVERS] Intel Ethernet/WiFi/Bluetooth
- Intel WiFi Drivers (Drivers Only) :
Drivers - 3xxx/7xxx/8xxx
- Intel Bluetooth Drivers (Drivers Only) :
Drivers - 3xxx/7xxx/8xxx/9xxx/AX2x0
[DRIVERS] Realtek Audio (NB | Intel 6x/7x/8x/9x/1xx)
- Realtek Audio Drivers (HDA - ASUS ROG MaxxAudio NB)
You have an ASUS ROG MaxxAudio notebook.
Follow scrupulously your CLEANUP process then your INSTALL process, for the next drivers packages that I would release, you will can directly follow your UPDATE process.
Thank you for the drivers. I appreciate your help.
