Results 1 to 2 of 2
    ROG Member Array
    Dec 2011
    11
    14
    Question G703GX-XB76 PROBLEM: Power via the 2 inputs has become intermittent
    It is a problem after 5 months of use, it worsens when hot from gaming. A quick reach to push the 90 degree jack back in. This is not about the jack falling out and onto the floor but rather a push in of about 1 mm will fix it, for a second. Also the 2 power bricks are fine, Is there a solution?
    Moderator Array
    Feb 2019
    14
    705
    Hello g53ok,
    I'm sorry it's a bit confusing,
    do you mean that the power jack is loosen?
    or the device is having high temperature and then the power supply is not stable?
