Results 1 to 6 of 6
    ROG Member Array
    Sep 2013
    22
    Gl504gm bios 312 issue with undervolt
    Hi all
    Bios updated to 312 now the undervolt option in intel XTU is now grayed out. Throttlestop will not apply settings either.
    How come this has been stopped ?
    How can I flash back to previous bios ?
    Thanks
    ROG Guru: Yellow Belt Array
    May 2011
    22
    141
    Quote Originally Posted by Daniel Shaw View Post
    Intel uncovered a security vulnerability called Plundervolt. Intel decided that blocking CPU voltage control while in Windows would be the easiest and cheapest way to handle this problem.
    https://www.intel.ca/content/www/ca/...rocessors.html
    Hopefully your computer allows you to go back to the previous BIOS version.
    Moderator Array
    Mar 2018
    19
    31
    Hi Daniel Shaw,
    As unclewbb said, the latest BIOS locked undervolt function due to Intel's statement.
    if you would like to downgrade your BIOS, please try this link : https://dlcdnets.asus.com/pub/ASUS/G...504GMAS311.zip
    or directly click " See All Downloads" below BIOS and select BIOS 311 from here : https://www.asus.com/hk/Laptops/ROG-...HelpDesk_BIOS/
    Sorry if it caused any inconvenience.
    Thank you!
    ROG Guru: White Belt Array
    Jan 2019
    80
    Quote Originally Posted by Joanne@ASUS View Post
    Hi Daniel Shaw,
    Thank you!
    May we know the detailed changelog of BIOS firmware from 306?
    ROG Guru: Yellow Belt Array xarot PC Specs
    xarot PC Specs
    Laptop (Model)Asus GL504GM
    MotherboardAsus Rampage VI Extreme
    Processori9-7980XE
    Memory (part number)Corsair Dominator Platinum 64GB CL16-18-18
    Graphics Card #1Palit RTX2080TI
    Sound CardIntegrated
    MonitorAsus PG279Q
    Storage #1Intel 750 1.2 TB PCIe
    Storage #2Samsung 960 Pro 1 TB
    CPU CoolerEK Supremacy EVO Full Nickel
    CasePhanteks Enthoo Primo
    Power SupplyCorsair AX1500i
    Keyboard Blackstorm Mech RGB
    Mouse Steelseries Rival 310
    Headset Sennheiser HD555
    Mouse Pad Razer Goliathus Extended
    OS Windows 10 x64
    xarot's Avatar
    Oct 2013
    44
    202
    Quote Originally Posted by Joanne@ROG View Post
    Hi Daniel Shaw,
    Thank you!
    ASUS has taken down any old BIOS versions for this laptop. Basically the laptop is now useless because it is giving FPS drops to 3 fps every 10 seconds in Cyberpunk.
    Main: Xeon W-3175X - Dominus Extreme - 48 GB Corsair Dominator Platinum DDR4-3200 - Palit RTX2080TI H2O - Phanteks Enthoo Primo - Corsair AX1500i - Samsung 960 PRO 1 TB + Intel 600P 1TB
    HTPC: i7-6950X - X99-M WS - 32 GB G.Skill RipjawsV DDR4-2400 - GTX1070 - Bitfenix Pandora - Corsair AX860 - Intel 750 400 GB + Samsung 1 TB 850 EVO
    All around: i7-7980XE - H150i Pro - Rampage VI Extreme - 64 GB G.Skill 4000 CL18-19-19-39 - Strix RTX2060 - In Win 101C - Samsung 960 EVO 512 GB
    Jan 2019
    80
    Quote Originally Posted by xarot View Post
    they recently release the bios 313, I maybe have a copy of 311 which undervolt 9is still allowed
Tags for this Thread
