Results 1 to 4 of 4
    New ROGer Array
    Jul 2020
    2
    DOCP settings problem with Asus ROG STRIX B450-F GAMING
    MY problem is that when I turn docp on in bios and 3200 mhz my pc does not boot but turns off 3 times and turns it on again and then bios resets my ram to 2133 mhz, i can set to 2933 but not above that. my ram is corsair vengeance lpx 3200 2x8gb and i have the latest bios firmware Version 3103
    my pc setup is
    AMD Ryzen 3400g
    Asus ROG STRIX B450-F GAMING ATX AM4
    Corsair Vengeance LPX 16 GB (2 x 8 GB)
    New ROGer Array
    Jul 2020
    2
    I have my ram installed in a2 b2 i also tried different a1 a2, and b1 b2 and a1 b1 but i cant get the speed working at 3200 MHz. So whats wrong?
    ROG Junior Member Array
    Nov 2012
    2
    Quote Originally Posted by Jozweerd View Post
    Poorly constructed bios updates is the answer - I don't have your motherboard but on my crosshair hero VIII there is only one bios out of the last 6 that I can DCOP with specified RAM speed and timing - so you are not alone. You might want upgrade/downgrade your bios to test. Cheers!
    New ROGer Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    40
    726
    my pc setup is
    AMD Ryzen 3400g
    Corsair Vengeance has version number on it. Check it than match against QVL.... don't match, welcome to why you dont buy corsair vengance LPX for Ryzen systems.
    It is total loot box cheap crap.
Tags for this Thread
