Do we need to replace the thermal pad for m.2 drives?
pete_agreatguy
Hi all,
I need some advice.
My nmve m.2 drive (Corsair MP510 480GB) needs replacing due to a fault.
I have it installed in my ROG CROSSHAIR VII HERO m.2_1 (bottom slot) with the heatsink; which also included a thermal pad.
Do I need to replace this thermal pad when replacing my m.2 drive? If so, can you recommend me one?
Thanks in advance.
5 REPLIES 5
pete_agreatguy
I've researched some options quickly on Amazon. Would any of these be any good? If so, which would people recommend?
https://www.amazon.co.uk/hz/wishlist/ls/C2Q8YWHFN61B?ref_=wl_share
Arne_Saknussemm
Level 40
Arne Saknussemm wrote:
If you are careful, there should be no need to replace the thermal pad.
If something goes wrong... https://www.amazon.co.uk/Thermal-pad%EF%BC%8C-70x20x1mm-2280-Heatsinks/dp/B07PFBPK4V/ref=sr_1_7?crid...
Hi Arne, thank you for your reply. Due to the time I need the new part, I looked further through results.
Would this one be a good enough option? This one I can get the next following day when ordered rather than waiting for the one you linked to (2-3 weeks to arrive).
I'd rather replace the current one with a new one.
Arne_Saknussemm
Level 40
Yeah...looks the same thing to me...should be fine
Just to inform, I went and purchased the below thermal pad set and one of these is cooler than the default one which is supplied by Asus with the board. At least 5-8 deg C difference 🙂
https://www.amazon.co.uk/gp/product/B07PXG496K
Advancing Gene Nano Silicone Thermal Pad for M.2 2280 NVMe SSD Heatsinks, 70x20x1mm (2PCS Pack)
