Page 1 of 2 1 2 LastLast
Results 1 to 10 of 15
    New ROGer Array
    Aug 2020
    20
    Rog Scar 3 G731GV BIOS 308 Undervolt PROBLEM
    HI..I have a Asus rog scar 3 G731GV as soon as i updated bios 307 to 308 i have problem with cpu undervolting... xtu and throttlestop don't work and i also have drop fps. What can i do ?
    New ROGer Array
    Jul 2020
    18
    106
    Quote Originally Posted by souliar7 View Post
    Intel released a statement that all manufactures update the bios to disable all the wonderful things we want to use due to a vulnerability exploit that was discovered.
    I do think this is the article
    https://www.intel.com/content/www/us...-sa-00289.html
    Impact of vulnerability: Escalation of Privilege, Information Disclosure
    So yea its been disabled by the manufacturer...
    New ROGer Array
    Aug 2020
    20
    thanks for answer... i went back to 307 bios but every time i restart my laptop automatically installs the 308 bios..how can i stop this?
    New ROGer Array
    Dec 2019
    20
    5
    You can disable System Firmware in Device management concole (devmgmt.msc) and after that downgrade to 307 bios.
    New ROGer Array
    Aug 2020
    20
    Quote Originally Posted by sevamaxuz View Post
    You can disable System Firmware in Device management concole (gdevmmt.msc) and after that downgrade to 307 bios.
    where can i find gdevmt.msc and disable?
    New ROGer Array
    Dec 2019
    20
    5
    File name devmgmt.msc
    You can find it here "C:\Windows\System32\devmgmt.msc"
  7. #7
    New ROGer Array
    Aug 2020
    20
    Thanks...i found the file but i can't unistall it...
  8. #8
    New ROGer Array
    Dec 2019
    20
    5
    You don’t need to uninstall it, what you need is to open the file “devmgmt.msc”, find “System Firmware” device in devises tree and disable it (see attachment). After that you will be able to downgrade your bios to 307 and it will not be updated automatically.
  9. #9
    New ROGer Array
    Aug 2020
    20
    Thank you very much...i did it and downgrade bios to 307 and it was successful !
  10. #10
    New ROGer Array
    Dec 2019
    20
    5
    nice to hear that it solved you problem
