Results 1 to 4 of 4
    ROG Guru: Yellow Belt Array Asryan PC Specs
    Asryan PC Specs
    MotherboardAsus Maximus Hero XI
    Processor9900K
    Memory (part number)32GB G.SKILL Trident Z RGB / 3466Mhz
    Graphics Card #1EVGA RTX 3090 STRIX 0c
    Monitorlg 34gk950f
    Storage #1Sabrent Rocket
    Storage #2SSD: Samsung EVO 850 - 250Go + Samsung EVO 850 - 500Go
    CPU CoolerEK AIO 360 RG>B
    CasePhanteks P600S
    Power SupplySeasonic Prime TX 1000 Titanium
    Keyboard Corsair mk2 low profile
    Mouse Logitech G903 Chaos Spectrum
    Headset Arctis Pro wireless
    Headset/Speakers G560 Logitech
    OS Win 10 pro
    Oct 2016
    14
    188
    Maximus hero XI and NVME settings
    I've recently installed a Sabrent NVMe on my Maximus Hero XI.
    I wanted to know what is the best setting for it.
    Also, on the user manual it's notified that when the M.2_1(Socket 3) is operating in SATA mode, SATA port 2 (SATA6G_2) will be disabled but apparently on my board for what i've tested it's 5 and 6 which are disabled so I don't understand.
    Thanks for the help
    ROG Guru: Yellow Belt Array no1yak PC Specs
    no1yak PC Specs
    MotherboardMaximus Hero X I Wi-Fi/ Hero IX
    Processori9 9900KF/ i7 7700K both @ 4.7Ghz
    Memory (part number)Gskill F4-3200C16D / Corsair 2400 LPX
    Graphics Card #1Evga GTX 1070 SC ACX3 / Evga 1060 SC
    Sound CardEssence One DAC Muses edition
    MonitorEizo CG275W/ Dell U2719D
    Storage #1Samsung 970 EVO Plus NVMe / 950 Pro
    Storage #2Samsung EVO 950 Pro M.2 + 850 Pro 1TB
    CPU CoolerCorsair 150i pro/Noctua NHu-14S
    CaseCorsair 500D/ Corsair 450D
    Power SupplyEvga 650 P2 /Corsair HX750
    Keyboard Cherry MX6
    Mouse Corsair M65
    Headset/Speakers Corsair SP2500 + Senn HD650 + HD 600
    OS Windows 10 Pro x64 20H2
    Jun 2015
    156
    If your drive is NVme M.2 and not a sata M.2 (same fitment but the SSD sata m.2 is 6gb max ) Then what you are seeing is correct. I have the same MB with a Samsung 970 Evo plus (NVMe) in port M.2.1 and a 850 pro in port 1 of the Stata connection.
    ROG Guru: Brown Belt Array MrAgapiGC PC Specs
    MrAgapiGC PC Specs
    MotherboardAsus Maximus XI Code
    Processor9900K
    Memory (part number)CMK32GX4M4B3600C18
    Graphics Card #1STRIX-GTX1080ti-O8G-GAMING
    MonitorAOC AGON AG2701QX (2)
    Storage #1Samsung 960 EVO 256GB
    Storage #2Kingston Savage 500GB
    CPU CoolerNzxt X74 360mm AIO
    CaseNzxt H700
    Power SupplyEVGA 850 G2
    Keyboard Logitech G810
    Mouse Asus Spartha
    Headset Hyper X Cloud Revolver S
    Mouse Pad Hyper X Fury S 900mx420mm
    Headset/Speakers Logitech Z337
    OS Windows 10 64btis
    Network RouterTpLink Archer C9
    Accessory #1 EKWB FANs all of them
    MrAgapiGC's Avatar
    Nov 2011
    28
    1,809
    Quote Originally Posted by Asryan View Post
    Thanks for the help
    when you put the NVME in the m2_1 sata 0 is disable. if you put the nvme in m2_2 the 5/6 is disable. aside that that is it if you using 1502 bios. no settings at all. i recommend when nvme are use. use sata 3/2 (middle one) to be safe. there is no control switch o adjustments or any settings at all. nada. is all automatic. I recomend isntall the os, using CSM disable and othe type UEFI and clear the secure keys. (unless you are on enterprise environment )
    the bios control that you see that say hyper card is when ONLY use a riser card with a nvme carrier that hold 1 or more nvmes then you u use that on those scenarios aside that that is all
    I can retry these again if you want. there is no diference on the hero and code xi
    Learn, Play Enjoy!
    no1yak PC Specs
    Keyboard Cherry MX6
    Mouse Corsair M65
    Jun 2015
    156
    Quote Originally Posted by MrAgapiGC View Post
    Sorry I gave false info, my bad. @MrAgapiGC is totally correct . Need to engage brain before typing. The 850 is in slot 2 not 1 as previously stated.
