Results 1 to 5 of 5
Thread: Wireless Woes.
    ROG Guru: Yellow Belt Array Veovis PC Specs
    Veovis PC Specs
    Laptop (Model)Eluktronics N131WU
    MotherboardROG Stirx X570-I gaming
    ProcessorRyzen 3950X
    Memory (part number)CMK64GX4M2E3200C16
    Graphics Card #1Asus strix 1080 A8G
    Graphics Card #2Radeon Navi FE edition
    Sound CardCreative SoundBlaster x7
    MonitorMassdrop VAST
    Storage #1Samsung 850 Evo 1tb
    Storage #22 x Seagate Desktop SSHD ST4000DX001 4TB 64MB Cache
    CPU CoolerArctic liquid Freezer II 120 Liquid Cooling System
    CaseGamerstorm Tristellar
    Power SupplySeasonic PRIME titanium 650
    Keyboard Massdrop ALT keyboard
    Mouse Logitech G602 Mouse
    Headset Sennheiser HD58x Julibee
    Mouse Pad Laser megamat
    Headset/Speakers Creative SoundBlaster x7
    OS Windows 10 pro 64bit
    Network RouterNighthawk 8x
    Accessory #1 Blue Mic
    Accessory #2 Logitech Brio
    Accessory #3 AVEGANT GLYPH
    Veovis's Avatar
    Jan 2016
    27
    159
    Wireless Woes.
    Hey all,
    Im having issues with the built in AX wifi on the x570-i Strix Gaming board. I've deleted the wireless drivers, reinstalled them, rebooted the machine, set static parameters for ipv4, enabled DHCP, and Im still only getting 15-20 Mbps on an up to 600Mbps connection from my ISP. This connection switches antennas all the time even though only one is assigned and it won't load any sites that arent "Big Brand" (so google and facebook work fine but ASUS loads with no images when it "behaves")
    I feel like I'm missing something key to all of this. This problem plagued me with a previous modem and it still have me 20Mbps with similar results when hard wired.
    My Rog Phone II gets 300Mbps on this same wireless connection in the same Area which is making me think this issue resides in my device
    Veovis PC Specs
    Veovis's Avatar
    Jan 2016
    27
    159
    Update: the AX reciever says it's transmitting and receiving to the Wireless modem at 721 so it's possibly the browser I'm using or something that's translating the data.
    TeamROG Moderator Array xeromist PC Specs
    xeromist PC Specs
    Laptop (Model)Dell Inspiron 15 7567
    MotherboardMSI x470 Gaming Plus
    ProcessorAMD 2600X
    Memory (part number)16GB Crucial Ballistix Elite 3600
    Graphics Card #1ASUS GTX 1080 Strix
    MonitorBenQ BL3200PT
    Storage #1Intel 600p NVMe
    CPU CoolerWraith
    Casecustom Antec 900
    Power SupplyCorsair HX1000
    Keyboard Logitech Orion Spark
    Mouse Logitech MX500
    Headset Plantronics 777 with Oregon Aero upgrade
    xeromist's Avatar
    Jul 2010
    344
    8,018
    I would try hard wiring to see if it makes a difference, even if you have to temporarily move the machine next to your router. If it makes a difference then you know for sure it's flaky wireless.
    * Support disease research with Folding@Home *
    < < < Click the drop-down above my avatar for my PC specs!
    Veovis PC Specs
    Veovis's Avatar
    Jan 2016
    27
    159
    Further update: I pugged in my Cellphone (ROG II) that normally gets the 300Mpbs to the wireless router and used it as a tether/wireless card via USB C and it machine still only got 22Mbps. So that means it's definately a software issue if the AX card and AX antenna phone are giving the same results.
    Looks like I'll have to backup all my save data and nuke the OS drive, then reinstall the drivers from scratch if I want a better internet connection.
    Veovis PC Specs
    Veovis's Avatar
    Jan 2016
    27
    159
    Found the problem. It was Gamefirst V. The setting was gating the maxium for web. Now I gotta figure out how to tweak it so that it's not restricting what I'm doing at any given moment.
