GL504GW CPU FAN no more spinning
aupoi351
Hello there,
last month I started to encounter problems with the fans of my GL504GW.
I had the well known problem of the GPU fan going crazy and sometimes my CPU fan would not kick in or very tardily under load.
So I bought a pair of fan at aliexpress for that model and installed them.
All was good at the beginning but I noticed, when playing, that the CPU started to throttle aggressively.
After a few investigations in bios and armoury crate I noticed that the CPU fan was not spinning anymore!
So I decided to reinstall the original CPU fan but the problem remains, it's not spinning AT ALL!
Has anyone encountered a problem like this
How can I solve it?
I suspect a faulty motherboard or bad connector...if this is the case, I will have to send it to RMA but I fear that I lost the warranty because of the fan replacement, since I also had to repast when changing the fans (fans are under the heatsinks).
Can anyone at ASUS tell me if the warranty is void or not because of this?
Thank you all!
Blake1
Hello aupoi351,
I'm sorry to tell you that dismantling the device would break the warranty.
