Results 1 to 3 of 3
    ROG Junior Member Array Novantis PC Specs
    Novantis PC Specs
    Laptop (Model)ASUS ROG G750JM
    MotherboardASUSTek G750JM (BSN12345678901234567) v1.0
    ProcessorIntel Core i7-4700HQ CPU @ 2.40GHz, 4 cores, 8 Logical Processors
    Memory (part number)Hynix/Hyundai HMT451S6AFR8A-PB (x2)
    Graphics Card #1NVIDIA GeForce GTX860M
    Storage #1TOSHIBA MQ01ABD100 (1 Tb)
    OS Windows 8.1 (64-bit)
    Jan 2018
    1
    X570-E Gaming ATX AM4 0d Q-Code Amber DRAM No Post
    I'm putting together a new PC with the following components:
    • Asus ROG Strix X570-E Gaming ATX AM4 Motherboard
    • G.Skill Ripjaws V 64 GB (2 x 32 GB) DDR4-3600 CL18 Memory
    • AMD Ryzen 9 3950X 3.5 GHz 16-Core Processor
    • EVGA GeForce RTX 2080 SUPER 8 GB KO GAMING Video Card
    Right now everything is installed, but I'm getting a 0d Q-code and an amber DRAM light when powered on. No boot, no post, no bios. I've attempted to run a single stick of the G.Skill Ripjaws V 32Gb from every slot which produces the same error as running two sticks in the recommended A2 B2 configuration. These sticks are off the QVL, so I'm not sure why they aren't working. As a note, I'm getting this error with and without the modules installed, so my suspicion is that something else may actually be going on here. I don't have any other sticks of DDR4 DIMM to test unfortunately so I can't confirm my suspicion. I've reset the CMOS by removing the on board battery and replacing it after 5 minutes but that also hasn't had any effect.
    Suggestions? Should I try a bios flashback?
    Administrator Array Silent Scone@ROG's Avatar
    Mar 2016
    166
    2,156
    Quote Originally Posted by Novantis View Post
    Yes, use FB to flash to the latest UEFI and report back. You may want to try removing the CPU and cooler and reseating it, too.
    ROG Guru: Blue Belt Array RedSector73 PC Specs
    Laptop (Model)FA506IU-AL130T x 2
    MotherboardROG CROSSHAIR VIII HERO (WI-FI)
    ProcessorAMD Ryzen 9 3900X 12-Core Processor
    Memory (part number)4 x G.SKILL F4-3800C14D-16GTZN 14-16-16-36 Samsung B-Die
    Graphics Card #1Gigabyte Aorus RTX 2080 Ti Xtreme WaterForce (GV-N208TAORUSX W-11GC)
    Sound CardArctis DAC
    MonitorAsus ROG Swift PG348Q
    Storage #1ADATA SX8200PNP 1TB
    Storage #22 x Samsung SSD 840 EVO 250GB
    CPU CoolerCoolermaster Liquid Pro Master 360
    CaseEVGA DG-87 Gunmetal Grey Gaming Case
    Power SupplyEVGA SuperNOVA G2 750W Gold Power
    Keyboard Corsair K95 RGB Platinum
    Mouse Corsair Gaming Sabre RGB Gaming Mouse
    Headset ARCTIS Pro Wireless
    Mouse Pad Cooler Master MP750 RGB Cloth Gaming Mouse Pad Extra Large
    OS Windows 10 64bit Pro
    Network RouterRT-AC87U
    Apr 2018
    43
    878
    Suggestions?
    What cooler are you using or did you change the cpu backplate by chance. Overtightening of the CPU can cause non-boot and if you reverse the CPU backing plate (some come with their own and can be mounted backwards) can result in non-boot or '0d' Q code.
Tags for this Thread
