Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Guru: Yellow Belt Array MirceaForce PC Specs
    MotherboardASUS RAMPAGE VI EXTREME OMEGA
    ProcessorIntel® Core i9-7920X Processor Extreme Edition 4.2 GHZ auto
    Memory (part number)G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR
    Graphics Card #1NVIDIA GEFORCE GTX 1070 Founders Edition
    Graphics Card #2Samsung SSD 850 EVO 2TB
    Graphics Card #3Samsung SSD 850 PRO 2TB
    Sound CardSound Blaster Z
    MonitorIPS LED LG 27" 27UD69P 27 inch 4K 5 ms WhiteFreeSync - disabled, Display port
    Storage #1Samsung 950 PRO M.2 512GB OS
    Storage #2Samsung SSD 850 EVO 2TB
    CPU CoolerCORSAIR Hydro Series H80i v2
    CaseCooler Master: HAF X
    Power SupplySeasonic PRIME Titanium 850w
    Keyboard normal usb benq
    Mouse Razer Taipan
    Headset/Speakers Logitech Z-5500 digital
    OS Windows 10 x64 Pro up to date
    Network Router:Intel® Ethernet Server Adapter I210
    Accessory #1 LG OLED55C8PLA
    MirceaForce's Avatar
    Oct 2016
    8
    204
    Asus R6e omega aida 64 low ram write speed
    I'm now running the same confing on omega but have some issue with aida 64 engineer version see here
    On my older r6e did not have the full version of aida 64 so did not know the write bandwidth speed
    I'm running the latest bios 3105 did already reset bios, load optimize defaults ,the ram is the slots are like in the asus manual recomended settings, but the write speed to slow
    I did also xmp non xmp . but the write speed .....still the same for 3200mhz F4-3200C14Q-32GTZR, the ram is qvl checked in asus
    the motherboard is brand new did install ram twice checked for dirt or other before install
    Maybe there is a bug with aida 64 others test for ram bandwidth? or is because cpu ? see review on web but they use different cpus more powerful
    i did disable all power savings in win or bios
    did all stability tests, prime, cpu id, aida all pass
    Is there something to concern ?
    here is pass mark result
    in what i read here I think is the cpu
    https://www.guru3d.com/articles_page...review,13.html
    so for i9 7900 is 52gb write my i9 7920x almost 60gb and so on
    correct me if I'm wrong
    MB: ASUS RAMPAGE VI EXTREME-CPU: Intel Core i9-7920X Processor Extreme Edition 4.2 GHZ auto-CORSAIR Hydro Series H80i v2 Video: GEFORCE GTX 1070 Founders Edition. - G.SKILL 32GB 14-14-14-34 [Trident Z RGB] F4-3200C14Q-32GTZR- Seasonic PRIME Titanium 850 w-SSD: Samsung SSD 850 PRO 2TB x3 -SSD: Samsung 950 PRO M.2 512GB OS-Sound Blaster Z -Intel Ethernet Server Adapter I210 CASE:Cooler Master: HAF X MONITOR:IPS LED LG 27" 27UD69P 27 inch 4K 5 ms TV: LG OLED55C8P OS: Windows 10 x64 Pro up to date
    ROG Guru: Green Belt Array restsugavan PC Specs
    MotherboardRAMPAGE VI EXTREME BIOS 3301 MOD
    ProcessorIntel Core i9 7980XE 2.60GHz
    Memory (part number)64GB GSKILL 3.2 GHz 16-16-18-36 2T
    Graphics Card #1ASUS ROG POSEIDON 1080Ti
    MonitorSAMSUNG ODESSEY G9 49
    Storage #1SAMSUNG 970 EVO PLUS 1TB x 3
    Storage #2WD 4TB External HDD
    CPU CoolerNZXT KRAKEN 62
    CaseCorsair Carbine 540
    Power SupplyCorsair AX1200i
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Headset/Speakers Sony
    OS Windows 10 2021 Insider Preview 21327.1000
    Network RouterD-LINK
    restsugavan's Avatar
    Sep 2017
    75
    635
    Core i9 7980XE/R6E 3301 BIOS/Intel 02006B05 MCU 2021-01-15/VROC 7.5.0.1990/RST 18.35.0.4635/ME FW 11.12.82.1838 DV 2102.100.0.1044/64GB GSKILL/POSEIDON 1080i GTX + NVIDIA Driver 465.51 WHQL/3TB SAMSUNG 970 EVO PLUS + OMS Driver 18.31.3.1036 WHQL/Windows 10 Build 21327.1000/i219 V OROM 0.1.00/BA 0.1.16/12.19.1.32 WHQL AQC 107n FW 4.2.32 + AQC 2.2.2.0 WHQL/CAM 4.20.0/Realtek HD 6.0.9102.1 WHQL/SAMSUNG ODYSSEY G9 49
    ROG Guru: White Belt Array
    Dec 2018
    12
    88
    Quote Originally Posted by restsugavan View Post
    You'r true also what is propose of using AIDA64 if i can test it manually ?
    Can someone explain ?
    Also what i know from test to other on same cpu may vary due heat - temp ... but should be around same number or below it little bit
    New ROGer Array
    May 2020
    8
    Test with your RVIE and see if it is the same result. You can copy over your AIDA folder it will stay activated.
    Mouse Razer Taipan
    Oct 2016
    8
    204
    I think is the cpu because is only 60GB capable from that review that I posted ..
    Mouse Razer Taipan
    Oct 2016
    8
    204
    Quote Originally Posted by lLegendaary View Post
    what cpu do you use ?
  7. #7
    Mouse Razer Taipan
    Oct 2016
    8
    204
    Quote Originally Posted by DEJ915 View Post
    I have already told you that I don't have that board ...
  8. #8
    New ROGer Array
    May 2020
    8
    Quote Originally Posted by MirceaForce View Post
    Ah I missed that sorry. My 9800x has lower write speed in AIDA compared to my 7900x, I thought it was my new Omega I got but I tested it on my Apex, Asrock OCF and EVGA Dark with the same manual settings and the results were the same on all 3 other boards so it must be the cpu in my case at least. I tried different bios on omega as well at first and it made no difference.
  9. #9
    Keyboard Microsoft
    Mouse Microsoft
    Mouse Pad ASUS
    Sep 2017
    75
    635
    For reference
    For Reference 7980XE 2.6 GHz no overclock AIDA 64 5.25.5476 BETA
    Windows 10 2021 H2 Insider Preview 20206.1000
  10. #10
    Dec 2018
    12
    88
    9980xe
    i honestly don't care about AID or any benchmark apps
    I just want to see real performance by playing/watching movies/ editing ... also u may notice some windows update may effect your hardware little but as i told you it should be around the numbers ...
