im using g551vw and my cooling fan has been making funny noises and it seems its not blowing air the way it use to
now my country is **** and i cant find my laptops fan model
[i bought a fan for g551jw but didnt fit. didnt even notice the V and J till then]
and i was wondering is there any other fan model from other laptops or even companies other than asus that i can use instead? (it fits with the same voltage and power[ 5v-2.25w ] )
thank you.
