Page 1 of 2 1 2 LastLast
Results 1 to 10 of 18
    ROG Member Array
    Feb 2013
    18
    Exclamation G732LW MyAsus app reports battery and power adapter problem although...- solved?
    MyAsus app reports battery and power adapter problem although the laptop charges fine and the battery works fine. I want to mention that randomly while using the pc, a pop up message appears that says the power connector isn't plugged in properly although the charging is fine and not interpreted or anything. Also the connector is plugged in properly.
    2 weeks ago when I checked myasus app, evey hardware test passed and now randomly, battery and adapter issue. Why? and everything is working fine...
    ROG Member Array
    Feb 2013
    18
    The laptop model is G732LW
    New ROGer Array
    Aug 2020
    1
    adapter and battery prob report
    I have the same issue. battery and adapter errors are reported. I tried to charge my battery up to 100% and tested it again, this time, battery became OK but the adapter still failed.
    New ROGer Array
    Aug 2020
    2
    G732lws
    i have problem too battery and charger faiiled but all working fine
    ROG Member Array
    Feb 2013
    18
    Asus should fix their software...
    New ROGer Array
    Mar 2020
    2
    MyAsus report issues with Adapter too Zephyrus G14 grey no matrix
    Hi, like all of you for me was the same after the latest update, anyways my Battery charges perfect!, what I notice is now time to time Armoury Crate select Windows power mode connected or not. I think there must be an issue between what Win10 reports and what the software tool expects as a good result...I don't know. Please fix this in the next update.
  7. #7
    ROG Member Array
    Feb 2013
    18
    Also when launching certain games or game launchers, the sleep setting and brightness of the laptop change to never respectively 100%. Any idea why?
  8. #8
    ROG Member Array
    Feb 2013
    18
    I can confirm that the issue appeared also on my secondary laptop, a non ROG one, after updating the asus system control interface v2 to the latest version.
  9. #9
    Moderator Array
    Feb 2019
    13
    453
    Dear all,
    May I double check if your MyASUS App is 2.2.35.0?
    If so, please kindly wait for the next update of ASUS system control interface driver and MyASUS APP.
  10. #10
    ROG Member Array
    Feb 2013
    18
    It is. Any update on the fix?
Tags for this Thread
