G732LW MyAsus app reports battery and power adapter problem although...- solved?
KITT_2013
MyAsus app reports battery and power adapter problem although the laptop charges fine and the battery works fine. I want to mention that randomly while using the pc, a pop up message appears that says the power connector isn't plugged in properly although the charging is fine and not interpreted or anything. Also the connector is plugged in properly.
2 weeks ago when I checked myasus app, evey hardware test passed and now randomly, battery and adapter issue. Why? and everything is working fine...
1 ACCEPTED SOLUTION
Accepted Solutions
KITT_2013
Finally all issues have been fixed! Thank you ASUS for fixing your software. Now it works correctly! Latest version of ASUS System Control Interface V2 (2.29.10) fixed all issues discussed in this thread.
20 REPLIES 20
KITT_2013
The laptop model is G732LW
I have the same issue. battery and adapter errors are reported. I tried to charge my battery up to 100% and tested it again, this time, battery became OK but the adapter still failed.
i have problem too battery and charger faiiled but all working fine
KITT_2013
Asus should fix their software...
Hi, like all of you for me was the same after the latest update, anyways my Battery charges perfect!, what I notice is now time to time Armoury Crate select Windows power mode connected or not. I think there must be an issue between what Win10 reports and what the software tool expects as a good result...I don't know. Please fix this in the next update.
KITT_2013
Also when launching certain games or game launchers, the sleep setting and brightness of the laptop change to never respectively 100%. Any idea why?
KITT_2013
I can confirm that the issue appeared also on my secondary laptop, a non ROG one, after updating the asus system control interface v2 to the latest version.
Blake1
Dear all,
May I double check if your MyASUS App is 2.2.35.0?
If so, please kindly wait for the next update of ASUS system control interface driver and MyASUS APP.
KITT_2013
It is. Any update on the fix?
