Z490-E Strix issue with Intel i225-V power management
GettnBetter
Every time I put this Z490-E to sleep, the network adapter never reconnects. Driver currently is version 1.0.1.4
Connected to a Cisco 9300 multigigabit interface at 2.5gb/sec with portfast enabled or a generic 1GB netgear same issue.
I have tried unplugging the patch cable and plugging it back in and nothing.
I tried updating to the latest Intel i225-v drivers, Version 1.0.1.7 no change
I tried the complete updated armory, no change
I updating the firmware which is available on the ASUS drivers page to v1.45 and power cycled, no change
I cleared the entire computer, rebuilt from scratch, no change.
I can get the network to reattach after sleep is to open device manager, disable the adapter and re-enable it. This is quite annoying
Or, if I completely disable all power management from the network adapter, that works too but of course, this makes the adapter useless in a wake on lan scenario.
Has anyone encountered this sleep issue with the i225-v in their device and solved it?
rauf
Had similar issue on Z490 Apex. Try unistall drivers, then reinstal Chipset and all drivers for Network.
Hope that helps!
BenchAndGames
Just a faulty hardware, hope they start to implement the version3 on Z490 boards
