Results 1 to 2 of 2
    ROG Enthusiast Array
    Jul 2016
    45
    Addressable and RGB Header Control
    Hi
    I'm updating my build with Z490, I ve just ordered the z490 gaming e and I can see that it has 2 RGB 12v "old style" headers like in the z170 board and 2 new A-RGB 5volt header. So are they also seperately controlled via aura sync app? I mean I've already ordered some A-RGB parts like new fans and cpu waterblock but I'd like to keep my current RGB strips from my old setup, so are they controlled seperately per header type in Aura sync? So for example to have blue as static in the old RGB header and make patterns setting for the A-RGB header?
    Thanks
    New ROGer Array Jesseinsf PC Specs
    Jesseinsf PC Specs
    MotherboardASUS ROG Maximus XI Extreme (Z390)
    ProcessorIntel Core i9 9900K
    Memory (part number)Corsair CMW128GX4M4E3200C16
    Graphics Card #1NVIDIA - GeForce RTX 2080 Ti FE
    Sound CardCreative Labs Sound Blaster AE-9
    MonitorSamsung 32" UH750 QLED UHD Monitor
    Storage #1Samsung 970 Pro M.2 PCIe SSD 1TB
    CPU CoolerCooler Master MLX-D36M-A20PC-R1 w/ Noctua NF-F12 industrialPPC-2000 IP67 PWM x3 Fans
    CaseLian Li PC-011 Dynamic XL (ROG Certified)
    Power SupplyCooler Master V1200 Platinum
    Keyboard RAZER HUNTSMAN ELITE - LINEAR OPTICAL SWITCH (Red) w/ PBT Keycaps
    Mouse Razer Basilisk Ultimate with Charging Dock
    Headset Bowers and Wilkins P9 Signature
    Mouse Pad Razer Vespula V2 Mousepad
    Headset/Speakers Creative GigaWorks T40 Series II
    OS Windows 10 Pro for Workstations
    Network RouterROG Rapture GT-AC5300
    Accessory #1 Microsoft Xbox Elite Wireless Controller Series 2
    Accessory #2 Logitech BRIO ULTRA HD PRO WEBCAM
    Jesseinsf's Avatar
    Mar 2019
    22
    218
    Quote Originally Posted by pamarakos View Post
    Hi
    Thanks
    The short answer is: They are controlled as one. You will be able to see both separately in Aura Sync and you will be able to tell Aura Sync how many RGBs are connected to each header, but that is it.
